[Geoserver-users] Backup and restore GWC data with minimal downtime
I have a geowebcache of for an entire country for 20 zoom level have more than 85 Laksh tiles which is saved in C drive ,I need to move the same file into another system with minimum downtime , traditional copy and paste method take more than 2 days and Re caching is also not possible , is there any way to do that using any specific tool
Anas A
Jr.GIS Engineer, Trinity Mobility
facebook twitter linkedin googleplus
+917736368236
anas.24aj@anonymised.com
Tattamangalam,Palakkad,Kerala
Slightly out of scope of the list (probably better asked on serverfault.com), but I suspect something rsync based will probably do what you wish.
Jonathan
Anas A
facebook
twitter
linkedin
googleplus
+917736368236
anas.24aj@…84…
This message has been scanned for viruses by MailControl, a service from BlackSpider Technology
Click here to report this email as spam.
Another idea you might consider is shared folders:
Share the folder from the ORIGIN server C:\
Set up the environment variable/web.xml configuration parameter for GEOWEBCACHE_CACHE_DIR on DESTINATION server to point at ORIGIN\SHARED_FOLDER
Restart GeoServer/GeoWebcache
On DESTINATION server/drive, create a folder to store the cached tiles
Copy the tiles from ORIGIN server to DESTINATION; Use CMD prompt window or a comparison tool; I have had excellent experience with Beyond Compare, which also allows me to see what files are missing from DESTINATION and to copy blocks of files at a time.  Or, simply tell it to copy everything, minimize the window and go about my business.
Once the files are copied to DESTINATION, update the environment variable/web.xml configuration parameter for GEOWEBCACHE_CACHE_DIR to point at DESTINATION folder
References:
Setting up GeoWebCache [http://docs.geoserver.org/2.5.x/en/user/geowebcache/config.html#changing-the-cache-directory](http://docs.geoserver.org/2.5.x/en/user/geowebcache/config.html#changing-the-cache-directory)
Beyond Compare [http://www.scootersoftware.com/](http://www.scootersoftware.com/)
Chris Snider
Senior Software Engineer
Intelligent Software Solutions, Inc.
Description: Description: Description: cid:image001.png@...5633...
Sent: Tuesday, November 18, 2014 7:07 AM
To: ‘Anas A’; ‘GeoServer Mailing List List’
Subject: Re: [Geoserver-users] Backup and restore GWC data with minimal downtime
Jonathan
Sent: Friday, November 14, 2014 6:38 AM
To: GeoServer Mailing List List
Subject: [Geoserver-users] Backup and restore GWC data with minimal downtime
Anas A
facebook
twitter
linkedin
googleplus
+917736368236
anas.24aj@…84…
HR Wallingford and its subsidiaries uses faxes and emails for confidential and legally privileged business communications. They do not of themselves create legal commitments. Disclosure to parties other than addressees requires our specific consent. We are not liable for unauthorised disclosures nor reliance upon them.
If you have received this message in error please advise us immediately and destroy all copies of it.
HR Wallingford Limited
Howbery Park, Wallingford, Oxfordshire, OX10 8BA, United Kingdom
Registered in England No. 02562099
