Hellow, is possible to backup geoserver? because I had to reinstall and lost data loaded.
Thanks
Juan Pablo Virgillito
Thanks
In a production environment you should use an external config folder,
holding configuration and all or part of your spatial data. If you
didn't config it and are using the config folder you may copy it
before removing GeoServer, then replace the default configuration and
sample data with your copy.
Please note that this may not work if you are not reinstalling the
same version of GeoServer, i.e. if you are upgrading GeoServer to
newer release.
Kind Regards,
Stefano
41.95581N 12.52854E
http://www.linkedin.com/in/stefanoiacovella
http://twitter.com/#!/Iacovellas
2012/12/4 Juan Pablo Virgillito <jpv79@anonymised.com>:
data loaded.Thanks
LogMeIn Rescue: Anywhere, Anytime Remote support for IT. Free Trial
Remotely access PCs and mobile devices and provide instant support
Improve your efficiency, and focus on delivering more value-add services
Discover what IT Professionals Know. Rescue delivers
http://p.sf.net/sfu/logmein_12329d2d
Geoserver-users mailing list
