I have been experimenting with the KML Placemark templates. I get good
results when following the examples on the KLM Placemark Templates web page,
but I encounter problems when I try to use the templates with an ArcSDE
datastore.
Steps to duplicate the problem:
1.
Place a KML Placemark Template (the simple Hello World! example template) in
the feature type directory that uses an ArcSDE datastore. Example:
\featureTypes\sde_nrcs_SDE_NRCS.DBO.STATES\description.ftl
(This ArcSDE feature class was created by importing the States shapefile
distributed with GeoServer.)
2.
Request the output in KML format...
http://gisdev:8080/geoserver/wms?bbox=-130,24,-66,50&styles=population&request=GetMap&layers=topp:states&width=550&height=250&srs=EPSG:4326&Format=kml
3.
The returned KML is not well-formed. The Placemark element is never
completed. Portions of the resulting KML and GeoServer logs are listed at
the end of this post.
Here is my current configuration...
GeoServer 1.5.x (from nightly build geoserver-1.5.x-071207-bin.zip)
ArcSDE 9.2 plugin (gt2-arcsde.jar built by Saul on 7/3/2007)
- Tyler
Minor note: The word tranforming is missing an 's' in the GeoServer log
files
<kml>
<Document>
<name>mtri:sde_nrcs.DBO.states</name>
<Style id="GeoServerStyleSDE_NRCS.DBO.STATES.1">
<IconStyle>
<Icon>
<href>root://icons/palette-3.png</href>
<x>224</x>
<y>32</y>
<w>32</w>
<h>32</h>
</Icon>
</IconStyle>
<PolyStyle>
<color>b2ff0000</color>
<outline>0</outline>
</PolyStyle>
<LabelStyle>
<color>ff000000</color>
</LabelStyle>
<LineStyle>
<width>1</width>
</LineStyle>
</Style>
<Placemark>
<Style id="GeoServerStyleSDE_NRCS.DBO.STATES.2">
<IconStyle>
<Icon>
<x>224</x>
<y>32</y>
<w>32</w>
<h>32</h>
</Icon>
</IconStyle>
<PolyStyle>
<color>b200ff00</color>
</PolyStyle>
<LabelStyle>
</LabelStyle>
<LineStyle>
<width>1</width>
</LineStyle>
</Style>
<Placemark>
<Style id="GeoServerStyleSDE_NRCS.DBO.STATES.3">
<IconStyle>
<Icon>
<x>224</x>
<y>32</y>
<w>32</w>
<h>32</h>
</Icon>
</IconStyle>
<PolyStyle>
</PolyStyle>
<LabelStyle>
</LabelStyle>
<LineStyle>
<width>1</width>
</LineStyle>
</Style>
INFO | jvm 1 | 2007/07/13 14:27:40 | 625270 [btpool0-6] INFO
org.vfny.geoserver.servlets - handling request:
INFO | jvm 1 | 2007/07/13 14:27:40 | GetMap Request
INFO | jvm 1 | 2007/07/13 14:27:40 | version: 1.1.1
INFO | jvm 1 | 2007/07/13 14:27:40 | output format: kml
INFO | jvm 1 | 2007/07/13 14:27:40 | width height: 250,550
INFO | jvm 1 | 2007/07/13 14:27:40 | bbox: Env[-130.0 : -66.0, 24.0 :
50.0]
INFO | jvm 1 | 2007/07/13 14:27:40 | layers: mtri:sde_nrcs.DBO.states
INFO | jvm 1 | 2007/07/13 14:27:40 | styles: population
INFO | jvm 1 | 2007/07/13 14:27:40 | 625301 [btpool0-6] WARN
org.geoserver.kml - Failure tranforming feature to KML:SDE_NRCS.DBO.STATES.1
INFO | jvm 1 | 2007/07/13 14:27:40 | java.util.NoSuchElementException:
Could not locate FeatureTypeConfig 'mtri:SDE_NRCS.DBO.STATES'
INFO | jvm 1 | 2007/07/13 14:27:40 | at
org.vfny.geoserver.global.Data.getFeatureTypeInfo(Data.java:1204)
org.vfny.geoserver.global.GeoserverDataDirectory.findFeatureTypeDirName(GeoserverDataDirectory.java:85)
org.geoserver.template.GeoServerTemplateLoader.findTemplateSource(GeoServerTemplateLoader.java:106)
freemarker.cache.TemplateCache.acquireTemplateSource(TemplateCache.java:523)
freemarker.cache.TemplateCache.findTemplateSource(TemplateCache.java:499)
freemarker.cache.TemplateCache.getTemplate(TemplateCache.java:329)
freemarker.cache.TemplateCache.getTemplate(TemplateCache.java:229)
freemarker.template.Configuration.getTemplate(Configuration.java:487)
freemarker.template.Configuration.getTemplate(Configuration.java:452)
org.vfny.geoserver.wms.responses.featureInfo.FeatureTemplate.lookupTemplate(FeatureTemplate.java:233)
org.vfny.geoserver.wms.responses.featureInfo.FeatureTemplate.execute(FeatureTemplate.java:180)
org.vfny.geoserver.wms.responses.featureInfo.FeatureTemplate.title(FeatureTemplate.java:127)
org.vfny.geoserver.wms.responses.featureInfo.FeatureTemplate.title(FeatureTemplate.java:154)
org.vfny.geoserver.wms.responses.map.kml.KMLVectorTransformer$KMLTranslator.encodePlacemarkName(KMLVectorTransformer.java:575)
org.vfny.geoserver.wms.responses.map.kml.KMLVectorTransformer$KMLTranslator.encodePlacemark(KMLVectorTransformer.java:534)
org.vfny.geoserver.wms.responses.map.kml.KMLVectorTransformer$KMLTranslator.encode(KMLVectorTransformer.java:228)
org.vfny.geoserver.wms.responses.map.kml.KMLVectorTransformer$KMLTranslator.encode(KMLVectorTransformer.java:201)
org.vfny.geoserver.wms.responses.map.kml.KMLVectorTransformer$KMLTranslator.encode(KMLVectorTransformer.java:177)
org.vfny.geoserver.wms.responses.map.kml.KMLTransformer$KMLTranslator.encodeVectorLayer(KMLTransformer.java:190)
org.vfny.geoserver.wms.responses.map.kml.KMLTransformer$KMLTranslator.encode(KMLTransformer.java:110)
org.geotools.xml.transform.TransformerBase$XMLReaderSupport.parse(TransformerBase.java:677)
org.apache.xalan.transformer.TransformerIdentityImpl.transform(TransformerIdentityImpl.java:484)
org.geotools.xml.transform.TransformerBase$Task.run(TransformerBase.java:293)
org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:126)
org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:105)
org.vfny.geoserver.wms.responses.map.kml.KMLMapProducer.writeTo(KMLMapProducer.java:106)
org.vfny.geoserver.wms.responses.GetMapResponse.writeTo(GetMapResponse.java:496)
org.vfny.geoserver.servlets.AbstractService.doService(AbstractService.java:592)
org.vfny.geoserver.servlets.AbstractService.doGet(AbstractService.java:315)
org.geoserver.request.Dispatcher.dispatch(Dispatcher.java:192)
org.geoserver.request.Dispatcher.handleRequestInternal(Dispatcher.java:52)
org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:139)
org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:44)
org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:684)
org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:625)
org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:392)
org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:347)
javax.servlet.http.HttpServlet.service(HttpServlet.java:689)
javax.servlet.http.HttpServlet.service(HttpServlet.java:802)
org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:445)
org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1050)
org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:103)
org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1041)
org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:354)
org.mortbay.jetty.servlet.SessionHandler.handle(SessionHandler.java:226)
org.mortbay.jetty.handler.ContextHandler.handle(ContextHandler.java:627)
org.mortbay.jetty.handler.ContextHandlerCollection.handle(ContextHandlerCollection.java:149)
org.mortbay.jetty.handler.HandlerCollection.handle(HandlerCollection.java:123)
org.mortbay.jetty.handler.HandlerWrapper.handle(HandlerWrapper.java:141)
org.mortbay.jetty.Server.handle(Server.java:269)
org.mortbay.jetty.HttpConnection.handleRequest(HttpConnection.java:430)
org.mortbay.jetty.HttpConnection$RequestHandler.headerComplete(HttpConnection.java:687)
org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:492)
org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java:199)
org.mortbay.jetty.HttpConnection.handle(HttpConnection.java:339)
org.mortbay.jetty.nio.HttpChannelEndPoint.run(HttpChannelEndPoint.java:270)
org.mortbay.thread.BoundedThreadPool$PoolThread.run(BoundedThreadPool.java:475)
View this message in context: http://www.nabble.com/bad-KML-returned-from-Placemark-Templates-with-an-ArcSDE-datastore-tf4076322.html#a11585578
Hi Tyler,
Looking at the code it appears that exceptions are not being handled properly when processing the template... Its an easy fix.. .just committed it. Thanks for the bug report!!
So that should fix the problem with the kml being malformed... However as to why the feature type is not being found in the catalog... no too sure about that one...
Also I just fired off a nightly build as well just in case you wanted to try out the fix right away :).
-Justin
datastore.
1.
2.
3.
- Tyler
files
<kml>
<Document>
<IconStyle>
<Icon>
<x>224</x>
<y>32</y>
<w>32</w>
<h>32</h>
</Icon>
</IconStyle>
<PolyStyle>
</PolyStyle>
<LabelStyle>
</LabelStyle>
<LineStyle>
<width>1</width>
</LineStyle>
</Style>
<Placemark>
<IconStyle>
<Icon>
<x>224</x>
<y>32</y>
<w>32</w>
<h>32</h>
</Icon>
</IconStyle>
<PolyStyle>
</PolyStyle>
<LabelStyle>
</LabelStyle>
<LineStyle>
<width>1</width>
</LineStyle>
</Style>
<Placemark>
<IconStyle>
<Icon>
<x>224</x>
<y>32</y>
<w>32</w>
<h>32</h>
</Icon>
</IconStyle>
<PolyStyle>
</PolyStyle>
<LabelStyle>
</LabelStyle>
<LineStyle>
<width>1</width>
</LineStyle>
</Style>
org.vfny.geoserver.servlets - handling request: INFO | jvm 1 | 2007/07/13 14:27:40 | GetMap Request
50.0]
Justin Deoliveira
The Open Planning Project
http://topp.openplans.org
Justin,
After loading up the geoserver-1.5.x-071507-bin.zip nightly build, a KML
file now gets created, but the placemarks elements do not have description
elements, and there are a large group of errors in the log files.
- Tyler
INFO | jvm 1 | 2007/07/16 13:05:39 | 366301 [btpool0-6] INFO
INFO | jvm 1 | 2007/07/16 13:05:39 | GetMap Request
INFO | jvm 1 | 2007/07/16 13:05:39 | version: 1.1.1
INFO | jvm 1 | 2007/07/16 13:05:39 | output format: kml
INFO | jvm 1 | 2007/07/16 13:05:39 | width height: 250,550
INFO | jvm 1 | 2007/07/16 13:05:39 | bbox: Env[-130.0 : -66.0, 24.0 :
50.0]
INFO | jvm 1 | 2007/07/16 13:05:39 | layers: mtri:sde_nrcs.DBO.states
INFO | jvm 1 | 2007/07/16 13:05:39 | styles: population
INFO | jvm 1 | 2007/07/16 13:05:39 | 366364 [btpool0-6] WARN
org.geoserver.kml - Error occured processing 'title' template.
INFO | jvm 1 | 2007/07/16 13:05:39 | java.util.NoSuchElementException:
INFO | jvm 1 | 2007/07/16 13:05:39 | at
INFO | jvm 1 | 2007/07/16 13:05:39 | 366473 [btpool0-6] WARN
org.geoserver.kml - Error occured processing 'description' template.
Continuum-3 wrote:
Hi Tyler,
-Justin
page,
datastore.
1.
in
2.
3.
at
- Tyler
files
<kml>
<Document>
<IconStyle>
<Icon>
<x>224</x>
<y>32</y>
<w>32</w>
<h>32</h>
</Icon>
</IconStyle>
<PolyStyle>
</PolyStyle>
<LabelStyle>
</LabelStyle>
<LineStyle>
<width>1</width>
</LineStyle>
</Style>
<Placemark>
<IconStyle>
<Icon>
<x>224</x>
<y>32</y>
<w>32</w>
<h>32</h>
</Icon>
</IconStyle>
<PolyStyle>
</PolyStyle>
<LabelStyle>
</LabelStyle>
<LineStyle>
<width>1</width>
</LineStyle>
</Style>
<Placemark>
<IconStyle>
<Icon>
<x>224</x>
<y>32</y>
<w>32</w>
<h>32</h>
</Icon>
</IconStyle>
<PolyStyle>
</PolyStyle>
<LabelStyle>
</LabelStyle>
<LineStyle>
<width>1</width>
</LineStyle>
</Style>
50.0]
Justin Deoliveira
This SF.net email is sponsored by DB2 Express
Download DB2 Express C - the FREE version of DB2 express and take
control of your XML. No limits. Just data. Click to get it now.
http://sourceforge.net/powerbar/db2/
Geoserver-users mailing list
View this message in context: http://www.nabble.com/bad-KML-returned-from-Placemark-Templates-with-an-ArcSDE-datastore-tf4076322.html#a11622191
So... the question becomes now that why cant your feature type be located in the catalog.... I notice that from teh request log there seems to be some case differences:
layers: mtri:sde_nrcs.DBO.states vs mtri:SDE_NRCS.DBO.STATES... This may be an issue specific to arcsde... Can you send the info.xml under your featureTypes directory for this type.
Saul: Could this be an issue specific to arcsde? Any ideas?
-Justin
Justin,
- Tyler
org.vfny.geoserver.servlets - handling request: INFO | jvm 1 | 2007/07/16 13:05:39 | GetMap Request
50.0]
Continuum-3 wrote:
Hi Tyler,
-Justin
page,
datastore.
1.
in
2.
3.
at
- Tyler
files
<kml>
<Document>
<IconStyle>
<Icon>
<x>224</x>
<y>32</y>
<w>32</w>
<h>32</h>
</Icon>
</IconStyle>
<PolyStyle>
</PolyStyle>
<LabelStyle>
</LabelStyle>
<LineStyle>
<width>1</width>
</LineStyle>
</Style>
<Placemark>
<IconStyle>
<Icon>
<x>224</x>
<y>32</y>
<w>32</w>
<h>32</h>
</Icon>
</IconStyle>
<PolyStyle>
</PolyStyle>
<LabelStyle>
</LabelStyle>
<LineStyle>
<width>1</width>
</LineStyle>
</Style>
<Placemark>
<IconStyle>
<Icon>
<x>224</x>
<y>32</y>
<w>32</w>
<h>32</h>
</Icon>
</IconStyle>
<PolyStyle>
</PolyStyle>
<LabelStyle>
</LabelStyle>
<LineStyle>
<width>1</width>
</LineStyle>
</Style>
50.0]
Justin Deoliveira
Justin Deoliveira
Justin,
Yes, it seems to be a problem with the case as you noted. I thought I
should match the case that is displayed when I look at the feature class in
ArcCatalog (i.e. sde_nrcs.DBO.states), but that seems to be what cause the
error messages in the log.
When I match the case of the info.xml file with the case shown in ArcCatalog
it produces the log errors.
info.xml file: <name>sde_nrcs.DBO.states</name>
But when I put the table name in all uppercase, no log errors are created:
info.xml file: <name>SDE_NRCS.DBO.STATES</name>
Using this, the KML placemark templates seem to work correctly.
Tyler
-Justin
Justin,
description
- Tyler
50.0]
Continuum-3 wrote:
Hi Tyler,
-Justin
page,
datastore.
1.
template)
in
shapefile
2.
3.
at
- Tyler
log
files
<kml>
<Document>
<IconStyle>
<Icon>
<x>224</x>
<y>32</y>
<w>32</w>
<h>32</h>
</Icon>
</IconStyle>
<PolyStyle>
</PolyStyle>
<LabelStyle>
</LabelStyle>
<LineStyle>
<width>1</width>
</LineStyle>
</Style>
<Placemark>
<IconStyle>
<Icon>
<x>224</x>
<y>32</y>
<w>32</w>
<h>32</h>
</Icon>
</IconStyle>
<PolyStyle>
</PolyStyle>
<LabelStyle>
</LabelStyle>
<LineStyle>
<width>1</width>
</LineStyle>
</Style>
<Placemark>
<IconStyle>
<Icon>
<x>224</x>
<y>32</y>
<w>32</w>
<h>32</h>
</Icon>
</IconStyle>
<PolyStyle>
</PolyStyle>
<LabelStyle>
</LabelStyle>
<LineStyle>
<width>1</width>
</LineStyle>
</Style>
24.0
50.0]
Justin Deoliveira
Justin Deoliveira
View this message in context: http://www.nabble.com/bad-KML-returned-from-Placemark-Templates-with-an-ArcSDE-datastore-tf4076322.html#a11628863
