I had the same problem. Found, that it depends if you are able to Access public IP/page from local network- If Access is able – then geoexplorer loads fast and works (login button) ok. If can not Access – problems apears.
It looks like the router‘s problem and didn‘t find a way to fix this…
A work around was to Access through vpn
Pagarbiai,
Paulius Litvinas
GIS konsultantas
From: Jody Garnett [mailto:jody.garnett@anonymised.com…84…]
Sent: Tuesday, April 22, 2014 3:16 PM
To: pablo zader
Subject: Re: [Geoserver-users] bad login - redirect IP
You may need to ask the GeoExplorer project for your question.
This email list is devoted to GeoServer. I know GeoServer configuration provides a base proxy URL setting for the situation you describe, perhaps GeoExplorer has something similar?
Jody Garnett
On Wed, Apr 16, 2014 at 1:19 AM, pablo zader <pzader@anonymised.com> wrote:
Hello list:
I have problems when I want to log the administrative user through GeoExplorer when geoserver is running on a server with public ip but redirection to a private ip.
GeoExplorer takes too long to load and when it finally starts the login button does not appear in the interface. (in firedebug can be seen that there is no of cookies data).
If I access the GeoExplorer from the internal network, the login button load properly, GeoExplorer fast loading and allows me to make the user login.
The only open through public ip port is 80. Instead for access through the internal network are all open ports.
I am using: geoserver 2.4.0 , Ubuntu 12.04 LTS
Thanks
Pablo J. Zader
Lic. en Cs. de la Computación
CONAE
pablo.zader@anonymised.com
"Los Grandes Hombres hablan sobre ideas…
Los Hombres Promedio hablan sobre cosas…
Los Hombres Pequeños hablan… de otros Hombres.
del libro Matemática estas ahi? A. Paenza "
Learn Graph Databases - Download FREE O’Reilly Book
“Graph Databases” is the definitive new guide to graph databases and their
applications. Written by three acclaimed leaders in the field,
this first edition is now available. Download your free book today!
http://p.sf.net/sfu/NeoTech
Geoserver-users mailing list
Geoserver-users@anonymised.come.net
