I’m trying to generate a map from a set of points with gs:BarnesSurface. The result is quite good but the transition between colors is too sharp. Which parameters affects the transition between colors?
I’m currentrly using ColorMap type=“ramp”.
Thanks
Franco
Don’t Limit Your Business. Reach for the Cloud.
GigeNET’s Cloud Solutions provide you with the tools and support that
you need to offload your IT needs and focus on growing your business.
Configured For All Businesses. Start Your Cloud Today. https://www.gigenetcloud.com/
