[Geoserver-users] Base Layer disappeared after adding more than 15 Overlays
Dear All,
I have developed a webmap application using Geoserver 2.4.0,Tomcat7 on Windows 2008 32bit Server. JVM Client.
I have enabled GeoWebCache to speedup the map loading and configured separate directories for GeoWebCache and Geoserver data directory.
In my application, I am loading GeoTiff images (Entire UK) as base layer 1st and then Postgis data (Vector data for plymouth) as overlays. Problem is When 20 Overlays are loaded, the base layer got disappeared. If I turnoff the 15 Overlay’s visibility, then the base layer came to visible.
I am unable to findout the problem as I am a newbie. Randomly I kept 4 to 5 Overlays On to see that base layer. i.e. I feel that there is no issue in Overlays because I can view all those layers (base and overlays) in Geoserver preview as well as GeoWebCache demo page. but is there any limitation to adding number of Overlays? 20 Overlays means is it exceed that limitation?
Please help share your suggestions/solutions. It will help me lot to fix this issue.
Many Thanks in Advance.
Here is my code for adding Base and Overlays:
Base Layers:
geoLays = new OpenLayers.Layer.WMS(
ODC Overview,
“http://” + geoIpAddress + “:8080/geoserver/gwc/service/wms”,
LAYERS: cite:ODC Overview,
STYLES: ‘’,
format: ‘image/png’
tileSize: new OpenLayers.Size(256, 256),
isBaseLayer: true
osMap.addLayers([geoLays]);
Overlays:
for (var i = 0; i < overlays.length; i++) {
var geoLayName = overlays[i].split(‘:’);
var workSpace = geoLayName[0];
var layerName = geoLayName[1];
layerName,
LAYERS: overlays[i],
STYLES: ‘’,
format: ‘image/png’
isBaseLayer: false
I found some error on Geoserver log but I am not sure due to this only it’s happend
The error is:
Request: getServiceInfo
2014-03-28 16:41:00,103 INFO [geoserver.wms] -
Request: getLegendGraphic
Strict = false
Format = image/png
Rules =
Locale = null
Height = 20
Width = 20
Layers = [null]
Styles = [StyleImpl[ name=green]]
FeatureType = null
Env = {}
Transparent = false
Scale = -1.0
Exceptions = SE_XML
LegendOptions = {}
Version = 1.0.0
Request = GetLegendGraphic
Get = false
RawKvp = {STYLE=green, VERSION=1.0.0, STRICT=false, FORMAT=image/png, HEIGHT=20, REQUEST=GetLegendGraphic, WIDTH=20}
BaseUrl = http://182.72.238.98:8080/geoserver/
RequestCharset = null
2014-03-28 16:41:00,118 INFO [geoserver.flow] - Running requests: 0, processing through flow controllers: 0
2014-03-28 16:41:10,290 WARN [wicket.Localizer] - Tried to retrieve a localized string for a component that has not yet been added to the page. This can sometimes lead to an invalid or no localized resource returned. Make sure you are not calling Component#getString() inside your Component’s constructor. Offending component: [MarkupContainer [Component id = subform]]
2014-03-28 16:41:20,868 ERROR [io.IObjectStreamFactory$DefaultObjectStreamFactory] - error writing object [Page class = org.geoserver.web.data.resource.ResourceConfigurationPage, id = 9, version = 1, ajax = 0]: null
java.lang.NullPointerException
at org.geoserver.gwc.layer.GeoServerTileLayerInfoImpl.getParameterFilters(GeoServerTileLayerInfoImpl.java:360)
at org.geoserver.gwc.layer.GeoServerTileLayerInfoImpl.writeReplace(GeoServerTileLayerInfoImpl.java:153)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at java.io.ObjectStreamClass.invokeWriteReplace(Unknown Source)
at java.io.ObjectOutputStream.writeObject0(Unknown Source)
at java.io.ObjectOutputStream.defaultWriteFields(Unknown Source)
at java.io.ObjectOutputStream.writeSerialData(Unknown Source)
at java.io.ObjectOutputStream.writeOrdinaryObject(Unknown Source)
at java.io.ObjectOutputStream.writeObject(Unknown Source)
at java.util.HashMap.writeObject(Unknown Source)
at sun.reflect.GeneratedMethodAccessor372.invoke(Unknown Source)
at java.io.ObjectStreamClass.invokeWriteObject(Unknown Source)
at org.apache.wicket.util.io.IObjectStreamFactory$DefaultObjectStreamFactory$2.writeObjectOverride(IObjectStreamFactory.java:121)
at org.apache.wicket.util.lang.Objects.objectToByteArray(Objects.java:1124)
at org.apache.wicket.protocol.http.pagestore.AbstractPageStore.serializePage(AbstractPageStore.java:203)
at org.apache.wicket.protocol.http.pagestore.DiskPageStore.storePage(DiskPageStore.java:840)
at org.apache.wicket.protocol.http.SecondLevelCacheSessionStore$SecondLevelCachePageMap.put(SecondLevelCacheSessionStore.java:332)
at org.apache.wicket.Session.requestDetached(Session.java:1403)
at org.apache.wicket.RequestCycle.detach(RequestCycle.java:1176)
at org.apache.wicket.RequestCycle.steps(RequestCycle.java:1462)
at org.apache.wicket.RequestCycle.request(RequestCycle.java:545)
at org.apache.wicket.protocol.http.WicketFilter.doGet(WicketFilter.java:484)
at org.apache.wicket.protocol.http.WicketServlet.doGet(WicketServlet.java:138)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:621)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:728)
at org.springframework.web.servlet.mvc.ServletWrappingController.handleRequestInternal(ServletWrappingController.java:159)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:923)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:852)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:882)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:778)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:305)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:210)
at org.apache.catalina.filters.CorsFilter.handleNonCORS(CorsFilter.java:439)
at org.apache.catalina.filters.CorsFilter.doFilter(CorsFilter.java:178)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:243)
at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:27)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:74)
at org.geoserver.flow.controller.IpBlacklistFilter.doFilter(IpBlacklistFilter.java:87)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:70)
at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:45)
at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:49)
at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:109)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:311)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:68)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:116)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:83)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:72)
at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:91)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:323)
at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:113)
at org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter.doFilter(GeoServerAnonymousAuthenticationFilter.java:53)
at org.springframework.security.web.authentication.AbstractAuthenticationProcessingFilter.doFilter(AbstractAuthenticationProcessingFilter.java:182)
at org.geoserver.security.filter.GeoServerUserNamePasswordAuthenticationFilter.doFilter(GeoServerUserNamePasswordAuthenticationFilter.java:115)
at org.springframework.security.web.authentication.rememberme.RememberMeAuthenticationFilter.doFilter(RememberMeAuthenticationFilter.java:146)
at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:87)
at org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:52)
at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:173)
at org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:134)
at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346)
at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:259)
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:75)
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:42)
at org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:47)
at org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:43)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:222)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:123)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:502)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:171)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:99)
at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:953)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:118)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:408)
at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1023)
at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:589)
at org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:312)
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
2014-03-28 16:41:20,868 ERROR [lang.Objects] - Error serializing object class org.geoserver.web.data.resource.ResourceConfigurationPage [object=[Page class = org.geoserver.web.data.resource.ResourceConfigurationPage, id = 9, version = 1, ajax = 0]]
2014-03-28 17:07:34,999 INFO [geoserver.wms] -
Request: getCapabilities
Namespace = null
UpdateSequence = null
Version = 1.3.0
Request = GetCapabilities
Get = false
RawKvp = {VERSION=1.3.0, SERVICE=wms, REQUEST=GetCapabilities}
2014-03-28 17:07:34,999 WARN [wms.capabilities] - Map output format text/html does not include mime type in output format names. Will be excluded from capabilities document.
2014-03-28 17:07:34,999 WARN [wms.capabilities] - Map output format application/xml does not include mime type in output format names. Will be excluded from capabilities document.
2014-03-28 17:07:35,202 INFO [geoserver.flow] - Running requests: 0, processing through flow controllers: 0
2014-03-28 17:07:35,765 INFO [geoserver.wfs] -
2014-03-28 17:07:35,983 INFO [geoserver.wfs] -
Request: getFeature
service = WFS
version = 1.1.0
baseUrl = http://182.72.238.98:8080/geoserver/
query[0]:
filter = [[ User_id = 230 ] AND [ the_geom bbox POLYGON ((-1282210.2409099 -584298.24979135, -1282210.2409099 1699083.8921631, 1968878.9044757 1699083.8921631, 1968878.9044757 -584298.24979135, -1282210.2409099 -584298.24979135)) ]]
srsName = EPSG:27700
typeName[0] = {http://www.opengeospatial.net/cite}ODC_Graphics_Data
outputFormat = text/xml; subtype=gml/3.1.1
resultType = results
2014-03-28 17:07:35,999 INFO [geoserver.flow] - Running requests: 0, processing through flow controllers: 0
2014-03-28 17:07:36,171 INFO [geoserver.flow] - Running requests: 0, processing through flow controllers: 0
2014-03-28 17:07:36,233 INFO [geoserver.flow] - Running requests: 0, processing through flow controllers: 0
2014-03-28 17:07:36,311 INFO [geoserver.flow] - Running requests: 0, processing through flow controllers: 0
2014-03-28 17:07:36,374 INFO [geoserver.flow] - Running requests: 0, processing through flow controllers: 0
2014-03-28 17:07:41,014 INFO [geoserver.flow] - Running requests: 0, processing through flow controllers: 0
2014-03-28 17:07:41,046 INFO [geoserver.flow] - Running requests: 0, processing through flow controllers: 0
2014-03-28 17:07:41,093 INFO [geoserver.flow] - Running requests: 0, processing through flow controllers: 0
2014-03-28 17:07:41,124 INFO [geoserver.flow] - Running requests: 0, processing through flow controllers: 0
2014-03-28 17:07:41,155 INFO [geoserver.flow] - Running requests: 1, processing through flow controllers: 0
2014-03-28 17:07:41,155 INFO [geoserver.flow] - Running requests: 0, processing through flow controllers: 0
2014-03-28 17:07:41,249 INFO [geoserver.flow] - Running requests: 2, processing through flow controllers: 0
2014-03-28 17:07:41,249 INFO [geoserver.flow] - Running requests: 0, processing through flow controllers: 0
2014-03-28 17:07:41,327 INFO [geoserver.flow] - Running requests: 1, processing through flow controllers: 0
2014-03-28 17:07:41,327 INFO [geoserver.flow] - Running requests: 0, processing through flow controllers: 0
2014-03-28 17:07:41,358 INFO [geoserver.flow] - Running requests: 0, processing through flow controllers: 0
2014-03-28 17:07:41,405 INFO [geoserver.flow] - Running requests: 0, processing through flow controllers: 0
2014-03-28 17:07:41,483 INFO [geoserver.flow] - Running requests: 0, processing through flow controllers: 0
2014-03-28 17:07:41,514 INFO [geoserver.flow] - Running requests: 1, processing through flow controllers: 0
2014-03-28 17:07:41,514 INFO [geoserver.flow] - Running requests: 0, processing through flow controllers: 0
2014-03-28 17:07:41,577 INFO [geoserver.flow] - Running requests: 0, processing through flow controllers: 0
2014-03-28 17:07:41,639 INFO [geoserver.flow] - Running requests: 0, processing through flow controllers: 0
2014-03-28 17:07:41,639 INFO [geoserver.flow] - Running requests: 1, processing through flow controllers: 0
2014-03-28 17:07:41,718 WARN [catalog.util] - There is code not closing CloseableIterator!!! Auto closing at finalize().
2014-03-28 17:07:41,718 INFO [geoserver.flow] - Running requests: 1, processing through flow controllers: 0
2014-03-28 17:07:41,718 INFO [geoserver.flow] - Running requests: 0, processing through flow controllers: 0
2014-03-28 17:07:41,780 INFO [geoserver.flow] - Running requests: 0, processing through flow controllers: 0
2014-03-28 17:07:41,843 INFO [geoserver.flow] - Running requests: 0, processing through flow controllers: 0
2014-03-28 17:07:41,858 INFO [geoserver.flow] - Running requests: 1, processing through flow controllers: 0
2014-03-28 17:07:41,858 INFO [geoserver.flow] - Running requests: 0, processing through flow controllers: 0
2014-03-28 17:07:41,889 INFO [geoserver.flow] - Running requests: 0, processing through flow controllers: 0
Thanks & Regards,
Venkat E
GIS Developer
I suspect one of the overlay layers does not have the transparency flag set to true.
Try;
layerName,
STYLES: ‘’,
transparent: true,
format: ‘image/png’
isBaseLayer: false
Russ
On 28 Mar 2014, at 14:22, venky <venky.src@anonymised.com> wrote:
Dear All,
Base Layers:
ODC Overview,
STYLES: ‘’,
format: ‘image/png’
isBaseLayer: true
Overlays:
layerName,
STYLES: ‘’,
format: ‘image/png’
isBaseLayer: false
The error is:
Strict = false
Format = image/png
Rules =
Locale = null
Height = 20
Width = 20
Layers = [null]
FeatureType = null
Env = {}
Transparent = false
Scale = -1.0
Exceptions = SE_XML
LegendOptions = {}
Version = 1.0.0
Get = false
Namespace = null
Version = 1.3.0
Get = false
Request: getFeature
service = WFS
version = 1.1.0
query[0]:
Thanks & Regards,
Venkat E
GIS Developer
Geoserver-users mailing list
Thanks for your response Russell. I have tried that transparency flag as you said but no improvement. Still I am facing the same issue.
Try;
layerName,
STYLES: ‘’,
transparent: true,
format: ‘image/png’
isBaseLayer: false
Russ
Dear All,
Base Layers:
ODC Overview,
STYLES: ‘’,
format: ‘image/png’
isBaseLayer: true
Overlays:
layerName,
STYLES: ‘’,
format: ‘image/png’
isBaseLayer: false
The error is:
Strict = false
Format = image/png
Rules =
Locale = null
Height = 20
Width = 20
Layers = [null]
FeatureType = null
Env = {}
Transparent = false
Scale = -1.0
Exceptions = SE_XML
LegendOptions = {}
Version = 1.0.0
Get = false
Namespace = null
Version = 1.3.0
Get = false
Request: getFeature
service = WFS
version = 1.1.0
query[0]:
Thanks & Regards,
Venkat E
GIS Developer
