[Geoserver-users] Base Maps
I’ve been looking over the GeoServer documentation for a bit and what I’m having real problems understanding is how to back WMS requests with other base maps like World Wind. Right now, my maps (e.g.http://localhost:8080/geoserver/wms?request=GetMap&layers=topp:states&styles=population&srs=EPSG:4326&width=600&height=600&format=image/png&bbox=- 126.325,12.797,-63.691,62.905) don’t look very “map like” because they appear to just be features on a white background. How can I set up GeoServer to be backed by real map looking data like World Wind or Virtual Earth?
– Matt
Check out the examples included with openlayers. There are many examples included here including Google maps, Yahoo, etc. Thisr really depends a bit on the mapping client that you intend to use. OpenLayers and GoogleMaps are both capable of displaying output from GeoServer, but their API’s are different. If all else fails, read the documentation! :wink:
– Matt
Defy all challenges. Microsoft(R) Visual Studio 2005.
Geoserver-users mailing list
How can I set up
Earth?
Hi Matt:
you will have to configure a georeferenced image as a coverage, after
which you can overlay vector layers (or even other rasters). In your
getmap request you will specify them as follows:
.../wms?request=GetMap&layers=base,states&....styles=raster, population
Alex
“Check out the examples included with openlayers.”
Isn’t openlayers just a javascript api? How will knowing the openlayers javascript API help me teach GeoSever how to render more map looking maps? I would think instead I need to be learning how to configure GeoServer to point to OpenLayers which in turn would be backed by, say, World Wind. I would think OpenLayers would be completely ignorant of GeoServer and as such I’m not sure how I would learn to configure GeoServer from the OpenLayers web site. I’m confused.
“OpenLayers and GoogleMaps are both capable of displaying output from GeoServer”
I’m more interested in the other way around. I just want to see maps in my browser as a result of a WMS call served by GeoServer that look as pretty as those demoed at FOSS4G. Right now all the example maps served from GeoServer have all white backgrounds. For example, here is a WMS url from the tutorial:
http://localhost:8080/geoserver/wms?request=GetMap&layers=topp:states&styles=population&srs=EPSG:4326&width=600&height=600&format=image/png&bbox=-126.325,12.797,-63.691,62.905
When I view that in my local web browser I see a solid colored united states on top of a white background. No oceans, no Canada, no rivers. Just a feature looking thing. At F0SS4G this image appeared on top of a more realistic looking Earth.
– Matt
– Matt
I also suggest you to have a little closer look to something that looks like you want it to be, and try to learn why it look like it does. Or why is does not look so appealing. For example, in your example request (...&layers=topp:states&styles=population...) you are just asking for a layer 'states', drawn with a style named as 'population' . If you want to see Canada, rivers, oceans etc. you must have the data and styling for those as well. But if you had, then you could as a map with a request like 'draw me a map with deep blue oceans, rivers green with light blue outlines, borders of Canada in blue and US states in red, with pink semi-transparent fill'. Or almost whatever you want. WMS standard has just a bit different syntax, but the difference is not big, actually.
-Jukka Rahkonen-
-----Original Message-----
From: geoserver-users-bounces@lists.sourceforge.net on behalf of Dejas Ninethousand
Sent: Tue 2.10.2007 21:36
To: Jason Pickering
Subject: Re: [Geoserver-users] Base Maps
"Check out the examples included with openlayers."
Isn't openlayers just a javascript api? How will knowing the openlayers
I'm not sure how I would learn to configure GeoServer from the OpenLayers
web site. I'm confused.
"OpenLayers and GoogleMaps are both capable of displaying output from
GeoServer"
I'm more interested in the other way around. I just want to see maps in my
the tutorial:
-- Matt
both capable of displaying output from GeoServer, but their API's are
> I've been looking over the GeoServer documentation for a bit and what
> I'm having real problems understanding is how to back WMS requests with
> 126.325,12.797,-63.691,62.905) don't look very "map like" because they
> Earth?
> -- Matt
> Geoserver-users@lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/geoserver-users
Perhaps I misunderstood your question. If you want to figure out how to get your maps to look like WorldWind then you need to properly construct a style for your vector and raster layers. Documentation abounds on this and need not be repeated here. The OGC website give extensive documentation on the standards for vector raster layers.
I thought you actually wanted to place the imagery, which is present in WorldWind (i.e. the BlueMarble WMS mosaic) as a background image to your otherwise rather plain maps, with a white background? If so, then OpenLayer or other JavaScript API’s (such as GoogleMaps) are fully capable of doing this. From your post it would seem that you want a realistic colored earth in the background. This is exactly what OpenLayers or similar API can do for you, when combined with your own data that can be served by Geoserver and style approrpiately with a Styled Layer Descriptor (SLD). Correct or am I still off in left field here? :-/
– Matt
– Matt
On Tue, October 2, 2007 8:15 pm, Dejas Ninethousand wrote:
I've been looking over the GeoServer documentation for a bit and what I'm
Virtual
Earth?
This is because the above request misses the &transparent=true directive
to make the layer an overlay.
This is done automatically by openlayers for all layers that are not
base maps, but if you do the request manually, you have to add the above
parameter.
Hope this helps
Earth?
-- Matt
As far as I know, Geoserver can't be a WMS client, so you can't specify a
layer/datastore that just forward the request to another WMS server.
Mapserver can this with the Connectiontype "WMS".
So your base maps must be in the format Geoserver supports, e.g shapefile,
GML, etc. Or you integrate the WMS resources in the chosen client
(OpenLayers, etc.)
Here is one base map
http://www2.demis.nl/mapserver/request.asp?service=WMS&version=1.1.1&BBOX=-180,-85,180,85&width=800&Height=600&SRS=EPSG:4326&TRANSPARENT=TRUE&BGCOLOR=0xFFFFFF&format=image/png&request=getmap&layers=Bathymetry,Countries,Borders,Coastlines
cheers
Jørn Vegard
