[Geoserver-users] Batch loader option?
I have been doing some work on a RESTful interface to the geoserver
configuration, but there are several problems with it at the moment that kept
me from mentioning it in this thread:
* It works only against trunk these days
* It's in the middle of an API redesign and so scripts built against it now
will probably fail horribly sometime in the near future.
* Like Andrea said, there are some issues with autoconfiguring bboxes for some
shapefiles.
It's also pretty lousy at detecting bad configurations at the moment so it's
not too hard to hose your data directory. Still, it might be worth a try if
you have 1000 shapefiles to configure (but back it up first!).
What documentation there is currently lives at
http://geoserver.org/display/GEOSDOC/RESTful+Configuration+API, feel free to
bother me about information there that is wrong/incomplete/confusing.
Hope this helps,
-David Winslow
On Wednesday 19 March 2008 08:09:17 Andrea Aime wrote:
Lehtonen, Mika ha scritto:
> Hi,
> I am not sure if you Luca were serious about building that script, but I
> will be anyway focusing on the problem in the near future. I have over
> 800 hundred and in the worst case nearly 1300 shp-files that I should
> load into geoserver some how. I ain't gonna do it by hands! :sunglasses: ... :cry:
> Andrea, where from do the the latLonBoundingBox and the nativeBBox come
> from in an info.xml. Are they read from the shape file while
> "registering" it? Do I have to dig them out of shapes in my script? Is
> it that generate button in the 'feature type editor' which generates
> them?
> I was thinking of going through the shp-directory with Cocoon's
> directory-generator and use a xsl-template to build those files/dirs,
> but obviously I have to get those coord. information somehow.
Hem, it's a bit of a chicken and egg there...
The SRS most of the time cannot be guessed properly from the .prj,
so I hope your shapefiles do have all the same projection.
The coordinates are read from the shapefile as well using the
shapefile datastore, there is nothing you can call now to just
give you the bbox of a random shapefile.
Yet, it seems to me David was working on some REST calls to upload
shapefiles and have geoserver figure out all the details for you?
David?
!DSPAM:4040,47e1027324981137850744!
Yes I were. Actually, I did something of the sort to load shapefiles into DB2, though they were all of the same extent and SRS, which made the task considerably easier.
Anyway, I had in mind only a wiki page on how to do this with Ant + XMLTask, not a full-fledged load utility.
I was thinking of going through the shp-directory with Cocoon's directory-generator and use a xsl-template to build those files/dirs, but obviously I have to get those coord. information somehow.
As Alexandre pointed out, OGR could come to the rescue... though I think a more elegant way would be to use GeoTools (look at http://svn.geotools.org/geotools/trunk/gt/modules/plugin/shapefile/
src/main/java/org/geotools/data/shapefile/ShapefileFileResourceInfo.java).
P.S. This job should be done by some pro...
In other words you're not volunteering, are you ? :wink:
    Luca Morandini
www.lucamorandini.it
Luca,
you don't happen to know how to batch load shapes into PostGIS database. Yep, it turned out that I might not be able to use shapes, because I need to do some filtering for the material. This is stupid. These shapes are detached out of a big database piece by piece following the geographical borders. Now I am forced to attach them back into a single database, doing some filtering and detaching the material in raster, piece by piece following the "map grid".
Yeah, a consult must also earn his living. The best part is that I know PostGIS as much as a pig knows about a windmill. So, I will be learning and getting money out of it. Why I am complaining?
RESTful sounds nice.
reg. mika
Luca Morandini kirjoitti:
    Luca Morandini
Defy all challenges. Microsoft(R) Visual Studio 2008.
Geoserver-users mailing list
You can batch load in PostGIS pretty easily using the "shp2pgsql" tool
to first create .SQL files, then using pgsql to load them. So the
workflow in a Linux shell would look like this: (db_name assumed to be
"my_database" for this example)
for i in `ls -1 *.shp | awk -F"." '{print $1}'`
do
shp2pgsql -D $i $i my_database > $i.sql
pgsql -d my_database -f $i.sql
done
Note that you could use "cut" instead of awk to split the filename from
the ".shp".
Roger
-----Original Message-----
From: geoserver-users-bounces@lists.sourceforge.net
[mailto:geoserver-users-bounces@lists.sourceforge.net] On Behalf Of
Lehtonen, Mika
Sent: Wednesday, March 19, 2008 8:50 AM
To: lmorandini@anonymised.com
Subject: Re: [Geoserver-users] Batch loader option?
Luca,
reg. mika
    Luca Morandini
--- This SF.net email is sponsored by: Microsoft Defy all challenges.
Watch out!
I am getting pimples of that jargon. Does it really work? Looks terrible but who cares.
Joke, joke! I was just using too long fine GUIs' before I jumped back to this hell. Have to copy-paste it.
Thanks a lot, I will need this. Last time I checked, there were 3300 shapes in my server. Should have been max. 800. =-O
mika
Roger.Andre@anonymised.com kirjoitti:
for i in `ls -1 *.shp | awk -F"." '{print $1}'` do shp2pgsql -D $i $i my_database > $i.sql pgsql -d my_database -f $i.sql done
the ".shp".
Roger
Lehtonen, Mika
Luca,
reg. mika
    Luca Morandini
--- This SF.net email is sponsored by: Microsoft Defy all challenges. Microsoft(R) Visual Studio 2008.
ROTFL! Wait, if you are going to cut and paste, use this instead:
for i in `ls -1 *.shp | awk -F"." '{print $1}'`; do; shp2pgsql -D $i $i
my_database > $i.sql; pgsql -d my_database -f $i.sql; done
Roger
Sent: Wednesday, March 19, 2008 2:13 PM
To: Andre, Roger/SEA
Cc: geoserver-users
Watch out!
but who cares.
mika
be "my_database" for this example)
from the ".shp".
Roger
Lehtonen, Mika
Luca,
database.
reg. mika
files/dirs,
va
    Luca Morandini
hello Mika,
take a look at:
  http://jira.codehaus.org/browse/GEOS-1390
it is not a batch loader but an interactive user-selectable shapefile to
PostgreSQL + PostGIS converter (using ANT) which has the additional
benefit of updating GeoServer catalog.xml.
the bulk of the validation and transformation logic can be re-used to
implement a batch style operation.
On Thursday 20 March 2008 02:50:10 am Lehtonen, Mika wrote:
Luca,
reg. mika
>> somehow.
>.java).
> Regards,
> Luca Morandini
>------ This SF.net email is sponsored by: Microsoft
> Geoserver-users@lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/geoserver-users
cheers;
rsn
Hi Roger,
thanks, it really did work, although I added a pipe and leave the sql-creation out because I couldn't get it working. I realize now that it may have been caused by a lack of rights in that directory. Anyway the pipe works. But I need more and I am not good at these.
Can you pass me any hint how to do this so that the first shp would create the table and the rest would append into it? Table name could and should be static.
I have also another question to anyone who knows shp2psql. Why can't I get the -s option to work. I have tried -s 2393, -s EPSG:2393, -s "EPSG:2393" and have been getting nothing but errors like something: "current transaction is aborted...".
Yet one stupid question. What's the difference between psql and pgsql commands?
reg
mika
Roger
From: Lehtonen, Mika [mailto:mika@anonymised.com] Sent: Wednesday, March 19, 2008 2:13 PM
Cc: geoserver-users
Watch out!
but who cares.
mika
to first create .SQL files, then using pgsql to load them. So the workflow in a Linux shell would look like this: (db_name assumed to be "my_database" for this example)
Note that you could use "cut" instead of awk to split the filename from the ".shp".
Roger
[mailto:geoserver-users-bounces@lists.sourceforge.net] On Behalf Of Lehtonen, Mika
Luca,
database.
reg. mika
va
    Luca Morandini
Never mind Roger, got it working. I just created an empty table with a proper structure, used -a option and replaced another $i with a name of that table. It seems to be working although I still can't understand why the -s option isn't always functioning. Anyway thanks for your contribution, it really helped.
cheers
mika
Lehtonen, Mika kirjoitti:
Hi Roger,
reg
mika
Roger
Cc: geoserver-users
Watch out!
but who cares.
mika
Roger
Luca,
database.
reg. mika
va
    Luca Morandini
Check out the new SourceForge.net Marketplace.
It's the best place to buy or sell services for
just about anything Open Source.
http://ad.doubleclick.net/clk;164216239;13503038;w?http://sf.net/marketplace
Hi Mika,
Apologies for not responding sooner. I’ve fallen a bit behind on the list traffic and missed your questions. I don’t have definitive answers for all of them, but will give tell you what I can below.
Q: Can you pass me any hint how to do this so that the first shp would
should be static.
A: Not sure I completely understand. You want the table to be created using the schema of the first shapefile, and then to be populated with the contents of all the subsequent shapefiles? If so, I think I would do exactly what you did and create an empty table with the correct schema, then append each of the shapefiles to it.
Q: I have also another question to anyone who knows shp2psql. Why can’t I
“EPSG:2393” and have been getting nothing but errors like something:
“current transaction is aborted…”.
-A: I have had problems specifying the SRS at load time as well. My solution has been to update the srid field in the in the PostGIS geometry_columns table after the data is all loaded. You can do that from an SQL prompt using the “setsrid” command:
update “table_name” set “the_geom” = setsrid (“the_geom”, 4326);
Check that it works:
select distinct SRID(“table_name”.“the_geom”) from “table_name”;
Q: Yet one stupid question. What’s the difference between psql and pgsql
commands?
A: psql is an application that provides a command line interface to the PostgreSQL system. pgsql is the term used when speaking about PL/pgSQL. PL/pgSQL is a loadable procedural language for the PostgreSQL database system. Basically it refers to PostgreSQL’s implementation of the ANSI SQL language - I think. :wink: It also appears to be used as an abbreviation when talking about “PostgreSQL” itself.
Roger
that table. It seems to be working although I still can’t understand why
the -s option isn’t always functioning. Anyway thanks for your
cheers
mika
Hi Roger,
sql-creation out because I couldn’t get it working. I realize now that
should be static.
commands?
reg
mika
for i in ls -1 *.shp | awk -F"." '{print $1}'; do; shp2pgsql -D $i $i
Roger
Cc: geoserver-users
Watch out!
but who cares.
Joke, joke! I was just using too long fine GUIs’ before I jumped back to
mika
You can batch load in PostGIS pretty easily using the “shp2pgsql” tool
be “my_database” for this example)
for i in ls -1 *.shp | awk -F"." '{print $1}' do shp2pgsql -D $i $i
Note that you could use “cut” instead of awk to split the filename
from the “.shp”.
Roger
Lehtonen, Mika
Luca,
you don’t happen to know how to batch load shapes into PostGIS
database.
raster, piece by piece following the “map grid”.
reg. mika
I was thinking of going through the shp-directory with Cocoon’s
files/dirs,
As Alexandre pointed out, OGR could come to the rescue… though I
va
P.S. This job should be done by some pro…
In other words you’re not volunteering, are you ? :wink:
Luca Morandini
— This SF.net email is sponsored by: Microsoft Defy all challenges.
It’s the best place to buy or sell services for
Roger André
GIS Developer/Analyst
Enterprise Management Solutions
CH2M HILL
Tel: 425.233.3042
Hi Roger,
and thank you for your reply. Actually I got all sorted out. I succesfully loaded three sets of shapes, each 415 pcs, into three different tables. I am not sure, but I think that the order of on which you enter the options into command line matters with shp2pgsql. I had also problems with -I option. With only three tables, I did the indexing afterwards. So I am nowadays using the exact order in which they are presented in the "Using PostGIS" manual. Maybe I am a little superstitous :wink: ?
Yep, I do understand the psql thing but ever second or third instruction says: use the command pgsql...
I appreciate your help, thanks.
- mika -
Roger Andre kirjoitti:
Hi Mika,
Apologies for not responding sooner. I've fallen a bit behind on the list traffic and missed your questions. I don't have definitive answers for all of them, but will give tell you what I can below.
should be static.
Q: I have also another question to anyone who knows shp2psql. Why can't I
-A: I have had problems specifying the SRS at load time as well. My solution has been to update the srid field in the in the PostGIS geometry_columns table after the data is all loaded. You can do that from an SQL prompt using the "setsrid" command:
  # update "table_name" set "the_geom" = setsrid ("the_geom", 4326);
  # select distinct SRID("table_name"."the_geom") from "table_name";
Q: Yet one stupid question. What's the difference between psql and pgsql
commands?
A: psql is an application that provides a command line interface to the PostgreSQL system. pgsql is the term used when speaking about PL/pgSQL. PL/pgSQL is a loadable procedural language for the PostgreSQL database system. Basically it refers to PostgreSQL's implementation of the ANSI SQL language - I think. :wink: It also appears to be used as an abbreviation when talking about "PostgreSQL" itself.
Roger
On Thu, Mar 27, 2008 at 3:18 PM, Lehtonen, Mika <mika@anonymised.com <mailto:mika@anonymised.com>> wrote:
    name of
    understand why
    cheers
    mika
    > Hi Roger,
    > thanks, it really did work, although I added a pipe and leave the
    > sql-creation out because I couldn't get it working. I realize
    now that
    > it may have been caused by a lack of rights in that directory.
    Anyway
    > the pipe works. But I need more and I am not good at these.
    > Can you pass me any hint how to do this so that the first shp would
    > create the table and the rest would append into it? Table name
    could and
    > should be static.
    > I have also another question to anyone who knows shp2psql. Why
    can't I
    > get the -s option to work. I have tried -s 2393, -s EPSG:2393, -s
    > "EPSG:2393" and have been getting nothing but errors like something:
    > "current transaction is aborted...".
    > Yet one stupid question. What's the difference between psql and
    pgsql
    > commands?
    > reg
    > mika
    > Roger.Andre@anonymised.com kirjoitti:
    > >> ROTFL! Wait, if you are going to cut and paste, use this instead:
    >> >> for i in `ls -1 *.shp | awk -F"." '{print $1}'`; do; shp2pgsql
    -D $i $i
    >> my_database > $i.sql; pgsql -d my_database -f $i.sql; done
    >> Roger
    >> -----Original Message-----
    >> From: Lehtonen, Mika [mailto:mika@anonymised.com]
    >> Sent: Wednesday, March 19, 2008 2:13 PM
    >> To: Andre, Roger/SEA
    >> Cc: geoserver-users
    >> Subject: Re: [Geoserver-users] Batch loader option?
    >> Watch out!
    >> I am getting pimples of that jargon. Does it really work? Looks
    terrible
    >> but who cares.
    >> Joke, joke! I was just using too long fine GUIs' before I
    jumped back to
    >> this hell. Have to copy-paste it.
    >> Thanks a lot, I will need this. Last time I checked, there were
    3300
    >> shapes in my server. Should have been max. 800. =-O
    >> mika
    >> Roger.Andre@anonymised.com kirjoitti:
    >> >> >>> You can batch load in PostGIS pretty easily using the
    "shp2pgsql" tool
    >>> >>> >> >> >>> to first create .SQL files, then using pgsql to load them. So the
    >>> workflow in a Linux shell would look like this: (db_name
    assumed to
    >>> be "my_database" for this example)
    >>> for i in `ls -1 *.shp | awk -F"." '{print $1}'` do shp2pgsql
    -D $i $i
    >>> my_database > $i.sql pgsql -d my_database -f $i.sql done
    >>> Note that you could use "cut" instead of awk to split the filename
    >>> from the ".shp".
    >>> Roger
    >>> -----Original Message-----
    >>> From: geoserver-users-bounces@lists.sourceforge.net
    <mailto:geoserver-users-bounces@lists.sourceforge.net>
    >>> [mailto:geoserver-users-bounces@lists.sourceforge.net] On
    Behalf Of
    >>> Lehtonen, Mika
    >>> Sent: Wednesday, March 19, 2008 8:50 AM
    >>> To: lmorandini@anonymised.com <mailto:lmorandini@anonymised.com>
    >>> Cc: geoserver-users@lists.sourceforge.net
    <mailto:geoserver-users@lists.sourceforge.net>
    >>> Subject: Re: [Geoserver-users] Batch loader option?
    >>> Luca,
    >>> you don't happen to know how to batch load shapes into PostGIS
    >>> >>> >> database.
    >> >> >>> Yep, it turned out that I might not be able to use shapes,
    because I
    >>> need to do some filtering for the material. This is stupid. These
    >>> shapes are detached out of a big database piece by piece
    following the
    >>> >>> >> >> >>> geographical borders. Now I am forced to attach them back into a
    >>> single database, doing some filtering and detaching the
    material in
    >>> raster, piece by piece following the "map grid".
    >>> Yeah, a consult must also earn his living. The best part is that I
    >>> know PostGIS as much as a pig knows about a windmill. So, I
    will be
    >>> learning and getting money out of it. Why I am complaining?
    >>> RESTful sounds nice.
    >>> reg. mika
    >>> Luca Morandini kirjoitti:
    >>> >>> >>> >>>> Lehtonen, Mika wrote:
    >>>> >>>> >>>> >>>> >>>>> I am not sure if you Luca were serious about building that
    script,
    >>>>> >>>>> >>>>> >>>>> >>>> Yes I were. Actually, I did something of the sort to load
    shapefiles
    >>>> into DB2, though they were all of the same extent and SRS,
    which made
    >>>> >>>> >> >> >>>> the task considerably easier.
    >>>> Anyway, I had in mind only a wiki page on how to do this with
    Ant +
    >>>> XMLTask, not a full-fledged load utility.
    >>>> >>>> >>>> >>>> >>>>> I was thinking of going through the shp-directory with Cocoon's
    >>>>> directory-generator and use a xsl-template to build those
    >>>>> files/dirs,
    >>>>> >>>>> >>>>> >>> >>> >>> >>>>> but obviously I have to get those coord. information somehow.
    >>>>> >>>>> >>>>> >>>>> >>>> As Alexandre pointed out, OGR could come to the rescue...
    though I
    >>>> think a more elegant way would be to use GeoTools (look at
    >>> va
    >>> >>> >>> >>>> >>>> >>>> >>>> >>>>> P.S. This job should be done by some pro...
    >>>>> >>>>> >>>>> >>>>> >>>> In other words you're not volunteering, are you ? :wink:
    >>>> Regards,
    >>>> Luca Morandini
    >>>> www.lucamorandini.it <http://www.lucamorandini.it>
    >>>> --- This SF.net email is sponsored by: Microsoft Defy all
    challenges.
    >>>> >>>> >> >> >>>> Microsoft(R) Visual Studio 2008.
    >>>> http://clk.atdmt.com/MRT/go/vse0120000070mrt/direct/01/
    >>>> _______________________________________________
    >>>> Geoserver-users mailing list
    >>>> Geoserver-users@lists.sourceforge.net
    <mailto:Geoserver-users@lists.sourceforge.net>
    >>>> https://lists.sourceforge.net/lists/listinfo/geoserver-users
    >>> This SF.net email is sponsored by: Microsoft Defy all challenges.
    > Check out the new SourceForge.net Marketplace.
    > It's the best place to buy or sell services for
    > just about anything Open Source.
Roger André
CH2M HILL
Tel: 425.233.3042
