[Geoserver-users] BBOX to heigth and width
Hi list,
I want to know how I know height and width corresponding to my BBOX for no distortion of the image.
I not sure I’m clear sorry.
Jim
Can you explain what you want to d exactly?
Assuming you want to be able to guess native resolution for a coverage
I don't think there is a way to do that via WMS calls. This might be
possible via REST or WCS but I would have to check.
Simone.
Ing. Simone Giannecchini
Founder - Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
phone: +39 0584983027
fax: +39 0584983027
mob: +39 333 8128928
http://simboss.blogspot.com/
http://www.linkedin.com/in/simonegiannecchini
On Thu, Sep 10, 2009 at 5:22 PM, Jimmy Aumard <jimmy.aumard@anonymised.com> wrote:
Hi list,
I not sure I'm clear sorry.
Jim
Let Crystal Reports handle the reporting - Free Crystal Reports 2008 30-Day
trial. Simplify your report design, integration and deployment - and focus
on
what you do best, core application coding. Discover what's new with
Crystal Reports now. http://p.sf.net/sfu/bobj-july
Geoserver-users mailing list
On Thu, Sep 10, 2009 at 11:22 AM, Jimmy Aumard <jimmy.aumard@anonymised.com> wrote:
Hi list,
calculate the aspect ratio of the boundingbox
              r=(map_width/map_height)
then chose a width (or height) say screen_width -> calculate height
              screen_height = screen_width/r
All will then be undistorted - the only wrinkle is that map_* are
doubles and screen_* are ints so there will be some rounding.
Ian
Here is what I want to do:
I have one point with lon/lat in WGS84, I want to calculate a BBOX which contains the point and i want to make a request to have an image but I don’t know which width and heigth i have to put in the request
I calculate my BBOX with: lon-0.015,lat-0.020,lon+0.015,lat+0.020
I have to make : r= 0.030/0.040=0.75
And screen_heigth=640
screen_width=640/0.75=853
It’s good?
Thanks for awnser.
Jim
2009/9/10 Ian Turton <ijturton@anonymised.com>
Hi list,
then chose a width (or height) say screen_width → calculate height
Ian
On Fri, Sep 11, 2009 at 4:39 AM, Jimmy Aumard <jimmy.aumard@anonymised.com> wrote:
contains the point and i want to make a request to have an image but I don't
It's good?
The maths looks right to me - only you can be sure if the map you get
back is distorted or not?
If you are using OpenLayers they have a center and zoom level method
that does the calculation for you I think.
Ian
Ian Turton
Sent from State College, PA, United States
