On Sun, Jan 25, 2015 at 11:42 AM, Shayan Zamani <sh.zamani92@anonymised.com>
wrote:
I'm new to Geoserver and I'm playing around with GeoWebCache currently.
Is there a way to use more than 16 tasks for tile seeding?
My CPU has 24 cores so I'd like to use 48 tasks.
The HTML page for seeding is just a simple front end the seeding ending,
I have not tried, but maybe a direct REST call will allow you to use a
larger number of threads:
http://geowebcache.org/docs/1.6.0/rest/seed.html
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
