[Geoserver-users] Best practice for Geoserver on windows server
I am reconfiguring my main server to use server 2008 vs multiple virtual servers under Citrix Xen. For those of you about there that run geoserver on a windows based platform what you recommend for the installation?
Setup geoserver using the windows installer or setting it up using the WAR file? Which seems to give the better/best response? Is either one or the other more stable? Especially if using the mosaicing options for raster files. Which seems more flexible??
Thanks in advance…
Robert
P.S. - I just got a basic server running using the new installer unser 32 bit server 2008. But before I go any further in setting this up, I would like to make sure I am probably getting the better setup.
