I have an Ubuntu server with GeoServer v2.2.1 on TomCat7 and a Apache server with PHP5.
I’ve created several pages using OpenLaysers that show maps from Geoserver.
This is working great.
I now want to restrict access to my Geoserver data so that only my apache server can show the maps. I don’t want to set up user accounts because my web pages are accessible to everybody.
So everybody can go to my web pages and see the data. But nobody can access my Geoserver data directly.
Is this possible?
Paul
http://serverfault.com/questions/218666/how-to-configure-tomcat-to-only-listen-to-127-0-0-1
Op 28 nov. 2012 16:49 schreef “Paul Meems” <bontepaarden@anonymised.com> het volgende:
Is this possible?
Paul
Keep yourself connected to Go Parallel:
INSIGHTS What’s next for parallel hardware, programming and related areas?
Interviews and blogs by thought leaders keep you ahead of the curve.
http://goparallel.sourceforge.net
Geoserver-users mailing list
Hi Paul,
You can use mod_proxy on apache.
http://httpd.apache.org/docs/2.2/mod/mod_proxy.html#proxypass
Set up a ProxyPass directive to forward requests from apache to GeoServer.
Of course you need to hide the Tomcat's http connector port, 8080 by
default, to avoid user accessing it.
Kind Regards,
Stefano
41.95581N 12.52854E
http://www.linkedin.com/in/stefanoiacovella
http://twitter.com/#!/Iacovellas
2012/11/28 Paul Meems <bontepaarden@anonymised.com>:
with PHP5.
I've created several pages using OpenLaysers that show maps from Geoserver.
server can show the maps. I don't want to set up user accounts because my
Is this possible?
Paul
INSIGHTS What's next for parallel hardware, programming and related areas?
You can use a firewall rule and restrict access to your geoserver port to the ip address of the box running apache.
As an example, you can use
https://help.ubuntu.com/8.04/serverguide/firewall.html
Christian
server with PHP5.
Is this possible?
Paul
This message was sent using IMP, the Internet Messaging Program.
Thanks all for your quick responses.
I will look into each suggestion.
Paul
2012/11/28 Stefano Iacovella <stefano.iacovella@anonymised.com>
Hi Paul,
Of course you need to hide the Tomcat’s http connector port, 8080 by
Kind Regards,
Stefano
41.95581N 12.52854E
with PHP5.
Is this possible?
Paul
