[Geoserver-users] Best way to serve thousands of imagery files?
I have >100,000 imagery files I would like to serve using GeoServer and would like to know the recommended way for serving these files? I tried to just import them all individually as files in a directory, but the GeoServer start-up time was over 2hrs!! I also tried to create an image pyramid from the files but could not get GeoServer to import the ImagePyramid as described in the documentation because it would not take the ImagePyramid directory as valid input because it wanted a file.
So what would be you guys recommended way for serving up very large data sets? Should I be using a database?
Thanks in advance!
Hi Ben,
You should use an ImageMosaic for this.
-Bob
Thanks in advance!
Is there no performance hit if the ImageMosaic ends up being several GBs in size?
On Tue, Feb 3, 2015 at 10:31 AM, Bistrais, Bob <Bob.Bistrais@anonymised.com> wrote:
Hi Ben,
-Bob
Sent: Tuesday, February 03, 2015 11:27 AM
To: GeoServer Mailing List List
Subject: [Geoserver-users] Best way to serve thousands of imagery files?
Thanks in advance!
That’s a fair question and I’m not an ImageMosaic expert (yet) either. But my understanding is that the ImageMosaic only accesses the image tiles needed for the given map extent. You need to create an index shapefile which points the images to their corresponding locations.
Perhaps some of our resident experts can provide more detail on how to set it up.
On Tue, Feb 3, 2015 at 10:31 AM, Bistrais, Bob <Bob.Bistrais@…6406…> wrote:
Hi Ben,
-Bob
Thanks in advance!
You can also set up multiple zoom levels (i.e. an image pyramid) allowing geoserver to perform quickly at different scales.
Dive into the World of Parallel Programming. The Go Parallel Website,
sponsored by Intel and developed in partnership with Slashdot Media, is your
hub for all things parallel software development, from weekly thought
leadership blogs to news, videos, case studies, tutorials and more. Take a
look and join the conversation now. http://goparallel.sourceforge.net/
Geoserver-users mailing list
Jody Garnett
Hi Ben,
-Bob
Thanks in advance!
in size?
Anedoctically, up to 100GB is fine, the issue is not much the overall size,
but the number of
files to open in order to serve a single output image, that should be kept
relatively small.
So you either have large tile files, you play with scale dependencies to
disable the layer
when zoomed out, or switch to image pyramid as Jody suggested
More info on the topic in this presentation:
http://www.slideshare.net/geosolutions/gs-steroids-sgiannecfoss4g20130103
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
So I created an ImagePyramid using gdal from command line and got a directory structure of the images at different resolutions… when I tried to use this directory via the web interface by following the instructions in the documentation I was unable to use the ImagePyramid because the geoserver web interface is expecting a file and not a directory path. How do I import an ImagePyramid into geoserver?
On Thu, Feb 5, 2015 at 1:13 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
Anedoctically, up to 100GB is fine, the issue is not much the overall size, but the number of
files to open in order to serve a single output image, that should be kept relatively small.
So you either have large tile files, you play with scale dependencies to disable the layer
Ing. Andrea Aime
@geowolf
Technical Lead
On Fri, Feb 6, 2015 at 12:14 AM, Ben Johnson <weagle08@anonymised.com> wrote:
directory structure of the images at different resolutions.. when I tried
Weird? The image pyramid was accepting a directory too, and in case it was
generated by gdal_relatile, it was also
going to reshuffle it a bit (moving all the files in the root directory in
a 0/ folder, as we cannot have files in the
root folder).
Wondering... is GeoServer able to write to that path? Maybe it failed
because it could not move around the files?
Ing. Andrea Aime
@geowolf
Technical Lead
thanks for the help guys! ImagePyramid was the answer, and for anyone doing this later when you use the gdal_retile tool you will have to move the images in the base directory into a 0/ directory as Andrea pointed out!
Thanks a lot!
On Fri, Feb 6, 2015 at 11:47 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
Weird? The image pyramid was accepting a directory too, and in case it was generated by gdal_relatile, it was also
going to reshuffle it a bit (moving all the files in the root directory in a 0/ folder, as we cannot have files in the
root folder).
Wondering… is GeoServer able to write to that path? Maybe it failed because it could not move around the files?
Ing. Andrea Aime
@geowolf
Technical Lead
So quick question. I created an image pyramid from my MrSID files and the resulting size was ~16* the size of the MrSID so I created an image pyramid of JP2K files instead because they get good compression and can be created using the gdal_retile tool however GeoServer fails to import an image pyramid of .jp2 files (I have the JPEG 2000 plugin properly included and see JP2K as a raster option). What imagery types are supported in a GeoServer image pyramid?
On Tue, Feb 10, 2015 at 3:26 PM, Ben Johnson <weagle08@anonymised.com> wrote:
Thanks a lot!
root folder).
Ing. Andrea Aime
@geowolf
Technical Lead
Hi Ben
I don’t know the answer to your question, but suspect it’s only GeoTIFFs.
More usefully however – did you use any compression on the tiles you created? If they’re aerial photo type things you can compress with JPEG compression for a very large saving. If they’re more thematic, you can use DEFLATE (lossless). The filesizes will still probably be a bit larger, but not 16 times so.
Jonathan
Thanks a lot!
root folder).
Ing. Andrea Aime
@geowolf
Technical Lead
This message has been scanned for viruses by MailControl, a service from BlackSpider Technology
Click here to report this email as spam.
Hi Ben,
the ImagePyramid internally uses ImageMosaic reader: each level of the pyramid is a mosaic of files.
Therefore, ImagePyramid can support any image format supported by ImageMosaic.
About the JP2K issue you have, which JP2K Driver are you using? (MrSID/Kakadu/ECW/…?)
Can you please share some logs about the JP2K import failure?
Best Regards,
Daniele
On Wed, Feb 11, 2015 at 5:38 PM, Jonathan Moules <J.Moules@anonymised.com> wrote:
Hi Ben
Jonathan
Sent: Tuesday, February 10, 2015 11:55 PM
To: Andrea Aime
Cc: Bistrais, Bob; GeoServer Mailing List List
Subject: Re: [Geoserver-users] Best way to serve thousands of imagery files?
Thanks a lot!
On Fri, Feb 6, 2015 at 11:47 AM, Andrea Aime <andrea.aime@anonymised.com7…> wrote:
root folder).
Ing. Andrea Aime
@geowolf
Technical Lead
HR Wallingford and its subsidiaries uses faxes and emails for confidential and legally privileged business communications. They do not of themselves create legal commitments. Disclosure to parties other than addressees requires our specific consent. We are not liable for unauthorised disclosures nor reliance upon them.
If you have received this message in error please advise us immediately and destroy all copies of it.
HR Wallingford Limited
Howbery Park, Wallingford, Oxfordshire, OX10 8BA, United Kingdom
Registered in England No. 02562099
Ing. Daniele Romagnoli
Senior Software Engineer
