Thanks Soroka. This is kind of what I was beginning to understand also. My issue here then would be how to get my data from using ArcMap over into a PostGIS database. I have my data in both an ESRI personal geodatabase and in .shp files using ArcMap.
I guess I am looking for the easy way out here because I am somewhat strapped for time right now.
----- Original Message -----
Sent: Tue, 2/10/2009 12:25pm
To: geoserver-users users <geoserver-users@lists.sourceforge.net>
Subject: Re: [Geoserver-users] Better understanding of how to get data into database
People use many different tools, but a large community has formed
around PostgreSQL / PostGIS. I have no numbers to rove this, but my
sense is that it's the most popular open-source solution for spatially-
enabled RDBMS work.
A. Soroka / Digital Scholarship Services R & D
the University of Virginia Library
On Feb 10, 2009, at 1:05 PM, Lists wrote:
New here to GeoServer and fairly new to the GIS community itself. I
have been self taught on the basics of ESRI's ArcMap and personal
geodatabases. I have a bit of data in an ESRI personal ArcSDE
database that I would like to interface with geoserver. Is this
possible? Even if it is, should I find a different database setup to
be more friendly with the open source community>
I will still need to use ArcMap at work, but trying to learn more
ways of doing things other than ESRI's as I consider everything
tools for the toolbox and try to use what is best for the current
situation.
Robert
Create and Deploy Rich Internet Apps outside the browser with
Adobe(R)AIR(TM)
software. With Adobe AIR, Ajax developers can use existing skills
and code to
build responsive, highly engaging applications that combine the
power of local
resources and data with the reach of the web. Download the Adobe AIR
SDK and
Ajax docs to start building applications today-http://p.sf.net/sfu/adobe-com_______________________________________________
Geoserver-users mailing list
Create and Deploy Rich Internet Apps outside the browser with Adobe(R)AIR(TM)
software. With Adobe AIR, Ajax developers can use existing skills and code to
build responsive, highly engaging applications that combine the power of local
resources and data with the reach of the web. Download the Adobe AIR SDK and
