[Geoserver-users] BlHow to configure HTTPS on GeoServer 2.7.0 on Windows Server 208 R2
Hello All,
I have installed GeoServer 2.7.0 on 64 bit Windows Server 2008 R2; the Windows Installer (geoserver-2.7.0.exe) in http://geoserver.org/release/2.7.0/ is used.
32 bit Java 7 Update 76 was installed too. I do not have any other web server software installations like Apache or Tomcat, etc. Therefore, the default jetty should be used.
Which Jetty version is included in GeoServer 2.7.0? Is it full Jetty installation?
The URL http://myGeoServer:8080/geoserver/web works fine.
I try to use the following link: http://www.eclipse.org/jetty/documentation/current/configuring-ssl.html
But I cannot configure the Configuring SslContextFactory section or after. My GeoServer installation does not have jetty-ssl-context.xml, jetty-https.xml, etc.
Can anyone provide instructions how to configure HTTPS on the GeoServer 2.7.0?
Thanks in advance.
Shang
Important message for customers about changes to the way you access council services
From 1st June 2014 the Customer Service Direct partnership will cease to provide
services for Suffolk County Council and Mid Suffolk District Council.
From that date services and the associated transactions will be managed by the
individual councils directly. During the period of transition you may receive
emails from csduk.com or midsuffolk.gov.uk or suffolk.gov.uk email addresses.
Emails sent to and from this organisation will be monitored in accordance
with the law to ensure compliance with policies and to minimise any
security risks.
The information contained in this email or any of its attachments may be
privileged or confidential and is intended for the exclusive use of the
addressee. Any unauthorised use may be unlawful. If you receive this email
by mistake, please advise the sender immediately by using the reply
facility in your email software.
Customer Service Direct - a partnership between BT, Suffolk County Council
and Mid Suffolk District Council. Customer Service Direct Ltd.
Registered in England No. 05111581 Registered Office:81 Newgate
Street, London, EC1A 7AJ
On Mon, Jun 22, 2015 at 12:36 PM, <shang.jin@anonymised.com> wrote:
Hello All,
installation?
It's an old Jetty 6 version, documentation for it cannot be found anymore
now that Codehaus shut down.
It is still suitable for a demonstration install, not for production. If
there is any volunteer that would
help us upgrade our install packages to a more recent version of Jetty or
Tomcat, that would be quite appreciated.
For production I'd suggest you to remove the default installer, install
Tomcat so that it runs as a service,
and deploy the geoserver.war file inside it instead
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
