it seems that there is a problem with rendering bold and/or italic fonts correctly which are *not* installed on the system but only put into the %GEOSERVER_DATA_DIR/styles folder.
The GS loads the font and renders it. However, if the font-weight is specified as 'bold' or the font-style as 'italic' in the SLD, the display is not quite correct. It is, however, correct for the 'normal' font-style/weight.
Now I made some tests and found out that the bold/italic fonts are correctly rendered only if they are installed on the system or put into the $JRE_HOME/lib/fonts folder. Then the web interface also recognises all font types as "being installed in the JVM". This is not the case (deliberately?) if the fonts are instead being put into the styles folder.
I attached some screenshots to illustrate the issue and show the slight differences in rendering. The geometry with the star fill gets the different font-styles assigned while the other geometries have the normal style. The screenshots with *_JRE.png show the correct rendering, those with *_styles.png the wrong one.
I tested this exemplarily with the font "Gudea" from Google Web Fonts (cf. http://www.google.com/fonts/specimen/Gudea) but it also happens with plain Arial...
I have three separate .ttf files for each font styling, i.e. "Gudea-Bold.ttf", "Gudea-Regular.ttf" and "Gudea-Italic.ttf".
My setup is:
- Ubuntu 13.04
- GeoServer 2.3.0
- Java version: Sun Microsystems Inc.: 1.6.0_45 (Java HotSpot(TM) Server VM)
The workaround to just install the fonts in the JVM is basically O.K. but can get annoying if you have many fonts and servers. I'd prefer the solution to have the fonts in the styles folder so if anyone knows anything about this issue I would appreciate any help!
Thanks in advance and best regards,
Matthias
On Thu, Sep 26, 2013 at 10:53 AM, Matthias Uden <matthias.uden@anonymised.com>wrote:
font-style/weight.
As far as I remember when we load font from the data dir the ability to
turn then bold/italic is lost, you basically
have to refer directly to the ttf file name having the styling you desire,
eg.., Gudea-Bold.ttf.
However, not sure how you'd get a bold/italic effect, unless you also have
a file like that.
It may be a limitation in our implementation, but as far as I can see Java
itself does not allow to load more
than a single TFF file when creating a font:
http://docs.oracle.com/javase/6/docs/api/java/awt/Font.html#createFont(int,%20java.io.File)
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Hi Andrea,
thanks for your explanation, it does make sense to me that this is not a bug but rather a limitation in the Java environment.
I'd say it's fine as long as you know about this behaviour and use the workaround instead. I just wanted to let you and the ML know, maybe there will be a solution for this in some future release..
Matthias
Am 30.09.2013 12:15, schrieb Andrea Aime:
<mailto:matthias.uden@anonymised.com>> wrote:
desire, eg.., Gudea-Bold.ttf.
have a file like that.
Java itself does not allow to load more
Ing. Andrea Aime
@geowolf
Technical Lead
October Webinars: Code for Performance
Free Intel webinars can help you accelerate application performance.
Explore tips for MPI, OpenMP, advanced profiling, and more. Get the most from
the latest Intel processors and coprocessors. See abstracts and register >
http://pubads.g.doubleclick.net/gampad/clk?id=60133471&iu=/4140/ostg.clktrk
Geoserver-users mailing list
