Caio Simone,
Here is the output of gdalinfo and I suppose that explains where the
blue color comes from since the color map defines 0 as exactly that
shade of blue.
Based on your comments and that colormap I set the BackgroundValues to
255 and both InputTransparentColor and OutputTransparentColor to
#000000. Now everything works wonderfully. I suppose I should have
studied that gdalinfo dump a little closer!
Thanks for the help.
Mark
Driver: GTiff/GeoTIFF
Files: ***.tif
Size is 2168, 2208
Coordinate System is:
GEOGCS["WGS 84",
DATUM["WGS_1984",
SPHEROID["WGS 84",6378137,298.257223563,
AUTHORITY["EPSG","7030"]],
AUTHORITY["EPSG","6326"]],
PRIMEM["Greenwich",0],
UNIT["degree",0.0174532925199433],
AUTHORITY["EPSG","4326"]]
Origin = (-97.277345999999994,49.416856000000003)
Pixel Size = (0.003600000000000,-0.002700000000000)
Metadata:
AREA_OR_POINT=Area
Image Structure Metadata:
INTERLEAVE=BAND
Corner Coordinates:
Upper Left ( -97.2773460, 49.4168560) ( 97d16'38.45"W, 49d25'0.68"N)
Lower Left ( -97.2773460, 43.4552560) ( 97d16'38.45"W, 43d27'18.92"N)
Upper Right ( -89.4725460, 49.4168560) ( 89d28'21.17"W, 49d25'0.68"N)
Lower Right ( -89.4725460, 43.4552560) ( 89d28'21.17"W, 43d27'18.92"N)
Center ( -93.3749460, 46.4360560) ( 93d22'29.81"W, 46d26'9.80"N)
Band 1 Block=2168x3 Type=Byte, ColorInterp=Palette
Color Table (RGB with 256 entries)
0: 7,23,178,255
1: 247,245,245,255
2: 124,137,224,255
3: 245,237,226,255
... snip ...
214: 21,47,9,255
215: 51,17,66,255
216: 0,0,0,255
217: 0,0,0,255
218: 0,0,0,255
... snip ...
253: 0,0,0,255
254: 0,0,0,255
255: 0,0,0,255
On Tue, Jun 4, 2013 at 6:38 AM, Simone Giannecchini
<simone.giannecchini@anonymised.com> wrote:
Ciao Mark,
please, read below...
Simone Giannecchini
GeoServer training in Milan, 6th & 7th June 2013! Visit
http://geoserver.geo-solutions.it for more information.
Ing. Simone Giannecchini
@simogeo
Founder/Director
Via Poggio alle Viti 1187
mob: +39 333 8128928
On Mon, Jun 3, 2013 at 9:37 PM, Mark <kc8khl2@anonymised.com> wrote:
Hello,
I have a number of geotiff files that I'm attempting to mosaic and use
as an overlay on top of a base map. My problem is that I can't get rid
of the a border on the boundary of the geotiff mosaic. I've set
BackgroundValues to -9999 and the OutputTransparentColor to 000000
which takes care of most of the area not occupied by images.
Can you paster here the output of the gdalinfo tool on one of these images?
Rationale. If your geotiff are RGB and they contain black portions we
can use the InputTransparentColor to remove such areas.
If the overall mosaic has holes (portions not covered by data) I would
suggest to set the BackgroundValues to 0 and leave the
OutputTransparentColor to 000000.
This is a two steps approach:
-1- use InputTransparentColor to remove blackportions within the images
-2- use BackgroundValues to ask for a black background
-3- use OutputTransparentColor to make the background go away
ok, that was 3 steps, but I guess you got the idea
The border seems to occur at almost all edges. For instance, I've
attached an image of the open layers preview for the west coast of the
US. (The actual image data is removed and replaced with a gray field.)
There are three tiles present in this portion of the mosaic, I'm
attempting to get rid of the blue border. The white area to the left
is what I want, transparent tiles. This blue border changes width
depending on the zoom level and the suggested_tile_size setting. The
bigger the tile size the wider the border.
Thinking, this is actually strange. If you configure the geotiff as a
single geotiff store does it look differently?
Which version of GeoServer are you working with?
The border isn't part of the geotiffs, I've checked, and I have no
idea why it is blue. I can try to make the border insubstantial by
changing the suggested_tile_size to something insanely small, but that
isn't an acceptable solution (it is already 32,32 in the attached
image)
K, this answer partially to my question above, however the gdalinfo
would be very useful anyway.
It would be probably also good to have access to a couple of samples
to reproduce the issue. You can
send them privately if you wish.
Any suggestions?
Mark
How ServiceNow helps IT people transform IT departments:
1. A cloud service to automate IT design, transition and operations
2. Dashboards that offer high-level views of enterprise services
3. A single system of record for all IT processes
http://p.sf.net/sfu/servicenow-d2d-j
Geoserver-users mailing list
