Importing property parcel polygons from here:
http://www.johnstonnc.com/mainpage.cfm?category_level_id=420&content_id=2054
NAD83 datum, unit=feet, North Carolina State Plane.
Geoserver renders the map, but somewhere in the pacific ocean.
Incorrect SRS?
I've tried using 4269, 2913, 2264, 32019 and 32119.
SRS reference source:
http://webhelp.esri.com/arcims/9.2/general/mergedProjects/wms_connect/wms_connector/..\wms_admin\srs_list.htm
View this message in context: http://www.nabble.com/Bounding-box-with-NAD83-datum-(incorrect-lat---long)-tp16754264p16754264.html
Incorrect SRS?
Most probably. spatialreference.org reports the following candidate codes:
http://spatialreference.org/ref/epsg/?search=north+carolina&srtext=Search
* EPSG:2264: NAD83 / North Carolina (ftUS)
* EPSG:3358: NAD83(HARN) / North Carolina
* EPSG:3404: NAD83(HARN) / North Carolina (ftUS)
* EPSG:32019: NAD27 / North Carolina
* EPSG:32119: NAD83 / North Carolina
It seems there are a couple you did not try out there. They may be of help. Otherwise... I really don't know...
