[Geoserver-users] bounding box
Hello,
I have a PostGIS store in Geoserver 2.4, where the computed native bounding box x,y and lat/long are incorrect. When I try to preview the layer, the layer is cut on the map. Could anyone help me resolve this problem? The postgis table was recently updated (more geometry added). I’m having problems with the new geometry added to the table. I have tried deleting the layer and adding it again and problem persists.
Jon
Go to the layer in the Administration interface.
"Under Bounding Box” click on ‘Compute from Data’ (and ‘Compute from native bounds’ ?). See if the coords change.
Save the layer
Russ
On 6 May 2014, at 19:26, Jonatan Malaver <jon.malaver@anonymised.com> wrote:
Hello,
Jon
Is your legacy SCM system holding you back? Join Perforce May 7 to find out:
&#149; 3 signs your SCM is hindering your productivity
&#149; Requirements for releasing software faster
&#149; Expert tips and advice for migrating your SCM now
http://p.sf.net/sfu/perforce_______________________________________________
Geoserver-users mailing list
It changed but not to the correct bounding box.
-------- Original message --------
Date:05/07/2014 3:04 AM (GMT-05:00)
To: Jonatan Malaver
Subject: Re: [Geoserver-users] bounding box
Save the layer
Russ
On 6 May 2014, at 19:26, Jonatan Malaver <jon.malaver@anonymised.com<mailto:jon.malaver@anonymised.com>> wrote:
Hello,
Jon
Geoserver-users@lists.sourceforge.net<mailto:Geoserver-users@anonymised.comrge.net>
If you have not yet done VACUUM ANALYZE, do not do it yet. Do:
  1. Select accurate extents with ST_Extent http://postgis.net/docs/ST_Extent.html
  2. Check what ST_Estimated_Extent shows http://postgis.net/docs/manual-2.0/ST_Estimated_Extent.html
  3. Do VACUUM ANALYZE
  4. Repeat 2.
See if 2. and 4. gives different results. If yes, we know that VACUUM ANALYZE is useful. Try then what extents Geoserver gets with count from data.
-Jukka Rahkonen-
To: Jonatan Malaver
Save the layer
Russ
Hello,
Jon
� 3 signs your SCM is hindering your productivity
� Requirements for releasing software faster
� Expert tips and advice for migrating your SCM now
See Jukka response,
if you are using the default settings in the postgis store it will compute the bbox using the estimated
extents function, if you want precise and up to date values you can disable it.
Mind, it will come at a cost, computing the bbox that way may take a while if you have many data
(e.g., millions of rows) and the cost will not just be paid on the user interface, but also for every
WFS request if you have the feature bounding options enabled in the WFS settings
On Wed, May 7, 2014 at 12:40 PM, Jonatan Malaver <jon.malaver@anonymised.com> wrote:
To: Jonatan Malaver
Save the layer
Russ
Hello,
Jon
Geoserver-users@anonymised.comceforge.net
Meet us at GEO Business 2014! in London! Visit http://goo.gl/fES3aK
for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
