Quick fix would be to feed the bounding box coordinates manually. That automatic computing does not take into account the newly added features must mean that something on the PostGIS side has not updated as supposed. Perhaps Geoserver is doing query with ST_Estimated_Extent and you should run VACUUM ANALYZE in your database http://postgis.net/docs/manual-2.0/ST_Estimated_Extent.html.
-Jukka Rahkonen-
Jonatan Malaver wrote:
Hello,
I have a PostGIS store in Geoserver 2.4, where the computed native bounding box x,y and lat/long are incorrect. When I try to preview the layer, the layer is cut on the map. Could anyone help me resolve this problem? The postgis table was recently updated (more geometry added). I’m having problems with the new geometry added to the table. I have tried deleting the layer and adding it again and problem persists.
Jon
