[Geoserver-users] BoundingBox axis troubles with WCS 2.0.1
Could you show us the whole GetCoverage request? A "valid slice" is not accurate enough for trying to repeat your issue.
-Jukka Rahkonen-
GEOSurfer wrote:
I have exactly the same Problem with Geoserver V2.5.3. The WCS 2.0.1 DescibeCoverage request retrieves:
-<gml:EnvelopeWithTimePeriod srsDimension="2" uomLabels="m m s"
axisLabels="X Y time" srsName="http://www.opengis.net/def/crs/EPSG/0/3857&quot;&gt;
<gml:lowerCorner>6113175.5 1167595.0</gml:lowerCorner>
<gml:upperCorner>6218105.0 1264624.625</gml:upperCorner> <gml:beginPosition>2015-08-10T00:00:00.000Z</gml:beginPosition>
<gml:endPosition>2015-08-12T23:00:00.000Z</gml:endPosition>
<gml:sequenceRule axisOrder="+2 +1">Linear</gml:sequenceRule>
<gml:startPoint>0 0</gml:startPoint>
Requesting a valid slice results in an exception "Empty intersection after subsetting".
If I change the axis, I get a "Failed to read the coverage
org.geotools.referencing.operation.projection.ProjectionException:
Latitude 6149640°00.0&amp;apos;N is too close to a pole. "
Hope someone can help.
View this message in context: http://osgeo-org.1560.x6.nabble.com/BoundingBox-axis-troubles-with-WCS-2-0-1-tp5218757p5219329.html
Geoserver-users mailing list
