Hi every one,
here is the scenario
I have an Ubuntu server, tomcat runing on it, and the geoserver web
application.
I also have posgresql and opengis running in the same box.
together with a nice set of shapefiles.
I transfer the shapefile to an sql script file. using shp2psql command.
shp2pgsql -s 27700 myfile.shp mytable > myfile.sql
next I execute the script and load the database with the information
psql -f myfile.sql -d mydb
add schema, add data source (mydb)
Then open geoserver config>data>FeatureType = add new feature from
datasource
again, add SRS number 27700, generate bouding box, after adding style
...sumit, apply and save
check demo, open layer succesfully shows myMap...
Now change demo using openLayers and with the Google map as a background
var gsat = new OpenLayers.Layer.Google(
"Google Sattelite",
{type: G_SATELLITE_MAP, 'sphericalMercator': true}
add my layer
//create WMS layer
var mylayer = new OpenLayers.Layer.WMS(
"My Layer",
"http://127.0.0.1/geoserver/wms?",
layers: 'myns:mymap',
styles: '',
srs: 'EPSG:27700', //again!!
format: 'image/png',
tiled: 'true',
tilesOrigin : "143.60260815000004,-43.851764249999995",
transparent: true
'opacity': 0.75, 'isBaseLayer': false, 'wrapDateLine':
true
Excelent! I can see my (polylines) map on screen... old on a second, (zoom
in closer) they it is a bit shifted (around 100 meters). Provably it didnt
calculate the curve of the earth ... (?)
Check on nabble and other forums, I only found very confusing information.
Does any one know what is the problem? ( and how to solve it )
many thanks in advance.
View this message in context: http://www.nabble.com/British-National-Grid-to-Google-projection-problem-tp22785551p22785551.html
