[Geoserver-users] Broken SqlServer Datastore after applying windows security update
One of our production geoservers (2.5) went out of buissnes tonight after its database server installed the security update https://technet.microsoft.com/library/security/MS14-066.
The updated server run a sql server 2012 Geoserver connects to this database from a linux machine trough the sql server and the app schema plugins.
We thought about setting the sql server in force encryption = false but it seems that the plugin always uses encryption if available.
The logs were full of these reaccurent tries to reconnect to the database.
Anyone know if this has been fixed in later versions of the sql server plugin or if there are any workarounds we could try.
Caused by: com.microsoft.sqlserver.jdbc.SQLServerException: The driver could not establish a secure connection to SQL Server by using Secure Sockets Layer (SSL) encryption. Error: “Server key”. ClientConnectionId:03ce94e1-9aa3-4d2f-853b-9eb1770ffd1a
at com.microsoft.sqlserver.jdbc.SQLServerConnection.terminate(SQLServerConnection.java:1667)
at com.microsoft.sqlserver.jdbc.TDSChannel.enableSSL(IOBuffer.java:1668)
at com.microsoft.sqlserver.jdbc.SQLServerConnection.connectHelper(SQLServerConnection.java:1323)
at com.microsoft.sqlserver.jdbc.SQLServerConnection.login(SQLServerConnection.java:991)
at com.microsoft.sqlserver.jdbc.SQLServerConnection.connect(SQLServerConnection.java:827)
at com.microsoft.sqlserver.jdbc.SQLServerDriver.connect(SQLServerDriver.java:1012)
at org.apache.commons.dbcp.DriverConnectionFactory.createConnection(DriverConnectionFactory.java:38)
at org.apache.commons.dbcp.PoolableConnectionFactory.makeObject(PoolableConnectionFactory.java:582)
at org.apache.commons.pool.impl.GenericObjectPool.borrowObject(GenericObjectPool.java:1148)
at org.apache.commons.dbcp.PoolingDataSource.getConnection(PoolingDataSource.java:106)
at org.apache.commons.dbcp.BasicDataSource.getConnection(BasicDataSource.java:1044)
at org.geotools.data.jdbc.datasource.AbstractManageableDataSource.getConnection(AbstractManageableDataSource.java:48)
at org.geotools.jdbc.JDBCDataStore.createConnection(JDBCDataStore.java:1737)
… 105 more
Caused by: javax.net.ssl.SSLException: Server key
at com.sun.net.ssl.internal.ssl.Handshaker.throwSSLException(Unknown Source)
at com.sun.net.ssl.internal.ssl.ClientHandshaker.processMessage(Unknown Source)
at com.sun.net.ssl.internal.ssl.Handshaker.processLoop(Unknown Source)
at com.sun.net.ssl.internal.ssl.Handshaker.process_record(Unknown Source)
at com.sun.net.ssl.internal.ssl.SSLSocketImpl.readRecord(Unknown Source)
at com.sun.net.ssl.internal.ssl.SSLSocketImpl.performInitialHandshake(Unknown Source)
at com.sun.net.ssl.internal.ssl.SSLSocketImpl.startHandshake(Unknown Source)
at com.microsoft.sqlserver.jdbc.TDSChannel.enableSSL(IOBuffer.java:1618)
… 116 more
Caused by: java.security.spec.InvalidKeySpecException: Unknown KeySpec type: java.security.spec.ECPublicKeySpec
at org.bouncycastle.jce.provider.asymmetric.ec.KeyFactory.engineGeneratePublic(Unknown Source)
at java.security.KeyFactory.generatePublic(Unknown Source)
at com.sun.net.ssl.internal.ssl.HandshakeMessage$ECDH_ServerKeyExchange.(Unknown Source)
… 124 more
Vänliga Hälsningar
Lukas
Lukas Bergliden
Civilingenjör
Mobil 070 644 96 61 Electrum 234, 164 40 Kista
Direkt 08 630 75 09 Kistagången 16, 7 tr
On Wed, Nov 12, 2014 at 11:46 AM, Lukas Bergliden <
plugins.
I don't think the data store has any support for encryption actually... the
only thing remotely related is the "integrated secuty" flag, if
you have it in the store configuration try enabling/disabling it.
Also I'd suggest to download a more recent JDBC driver from Microsoft, that
might help too
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
I updated trunk (GeoTools) to use the latest ms driver in a recent PR but it looks like the JIRA got lost so I’ll poke it later.
I’ll apply the security patch now and see if I can recreate the issue locally.
Ian
On Wed, Nov 12, 2014 at 11:46 AM, Lukas Bergliden <lukas.bergliden@anonymised.com> wrote:
I don’t think the data store has any support for encryption actually… the only thing remotely related is the “integrated secuty” flag, if
Also I’d suggest to download a more recent JDBC driver from Microsoft, that might help too
Ing. Andrea Aime
@geowolf
Technical Lead
I don’t have a Windows server machine but on an up-to-date windows 7 box the latest Microsoft driver works against SQLServer 2012.
Ian
PS Andrea I’ve cleaned up the pull request https://github.com/geotools/geotools/pull/586 that makes that change
Ing. Andrea Aime
@geowolf
Technical Lead
On Wed, Nov 12, 2014 at 12:25 PM, Ian Turton <ijturton@anonymised.com> wrote:
it looks like the JIRA got lost so I'll poke it later.
Hum... as far as I know the Microsoft driver is not on the repositories and
we cannot redistribute it... or are you talking about a switch to JTDS?
Ing. Andrea Aime
@geowolf
Technical Lead
I just changed the pom to reference the latest MS jar. Ive started on the jtds driver but got side tracked. Ill see if i can finish something today.
Ian
Hum… as far as I know the Microsoft driver is not on the repositories and we cannot redistribute it… or are you talking about a switch to JTDS?
Ing. Andrea Aime
@geowolf
Technical Lead
Ok, an update. Microsoft issued an update https://support2.microsoft.com/kb/2992611 that solves the problem. After applying this patch Geoserver is again able to connect to sql server.
I also updated the sql driver and all seems to be working fine.
Thank you for your assistance.
Vänliga Hälsningar
Lukas
Lukas Bergliden
Civilingenjör
On Wed, Nov 12, 2014 at 12:25 PM, Ian Turton <ijturton@anonymised.com.> wrote:
Ing. Andrea Aime
@geowolf
Technical Lead
