[Geoserver-users] Buffer function
Hi list,
I’m new in the list. I’ve begun to work with Geoserver 3 weeks ago and it’s useful. Now I’m doing more complex things and I have a question:
I have two point tables (A,B) in postgis. I would like to do the query below using a GetFeature request with the filter option. Is it possible???
The query is:
select A.the_geom from A,B where
intersects(A.the_geom,buffer(B.the_geom,10000));
If it’s possible any help with the sintax??? I’ve tried to use the buffer function but it doesn’t work, I think it’s a syntax problem.
Thanks in advance.
Manel Gimeno
