Hi Together
I tried to create styles with GeoExtStyler, but when there are more then
several stylesrules, you can't scroll them. So you can't click on the new
created rules and edit them. Is this bug known? And when yes is there a
solution?
Thanks
Fabio Renggli
I don't think that bug is known. I'm ccing the styler list. What browser is it on? Or is it with all browsers?
Fabio Renggli wrote:
Hi Together
solution?
Thanks
Fabio Renggli
Register Now & Save for Velocity, the Web Performance & Operations Conference from O'Reilly Media. Velocity features a full day of expert-led, hands-on workshops and two days of sessions from industry leaders in dedicated Performance & Operations tracks. Use code vel09scf and Save an extra 15% before 5/3. http://p.sf.net/sfu/velocityconf
Geoserver-users mailing list
Chris Holmes
OpenGeo - http://opengeo.org
I tried it with Firefox 3.0.9 and ie 7.
-----Original Message-----
Sent: Dienstag, 28. April 2009 16:50
To: Renggli Fabio (frenggli@anonymised.com)
Cc: geoserver-users@lists.sourceforge.net; styler@anonymised.com
Subject: Re: [Geoserver-users] Bug GeoExtStyler: Rulemenu not scrollable
Hi Together
solution?
Thanks
Fabio Renggli
Chris Holmes
Hi Fabio,
thanks for letting us know. This is now fixed on trunk, and the fix will
be included in the next release.
See http://projects.opengeo.org/styler/ticket/62
Andreas.
Hi Together
solution?
Thanks
Fabio Renggli
Andreas Hocevar
OpenGeo - http://opengeo.org/
Hello Andreas
Thanks for fixing this issue that fast. I tried to build the styler from the
trunk, but it won't work. Please can you help me here either with a little
howto or send me the new built styler?
Fabio
From: Andreas Hocevar [mailto:ahocevar@anonymised.com]
Sent: Dienstag, 28. April 2009 20:46
Hi Fabio,
Andreas.
Hi Together
solution?
Thanks
Fabio Renggli
Andreas Hocevar
Hi Fabio,
I created a quick howto: http://projects.opengeo.org/styler/wiki/howto/build
In the meantime, I also committed the updated single file builds to
trunk, so you do not need to build them yourself using JSTools. Just
follow the howto and everything should work fine.
Andreas.
Hello Andreas
Fabio
Hi Fabio,
Andreas.
Hi Together
solution?
Thanks
Fabio Renggli
Andreas Hocevar
