I’m using GeoServer to create mbtiles files of some of my maps.
I want to create an mbtiles file of a layer group composed of multiple layers.
Using the wms/getMap service with the format mbtiles / application/x-sqlite3 the file is created correctly.
Instead, using the gs:mbtiles plugin via WPS to create an mbtiles file of the same layerGroup, the system returns an error of the following type reporting that the layer is not found.
<wps:ExecuteResponse xml:lang=“en” service=“WPS” serviceInstance=“https://historicalkat.provincia.tn.it/geoserver/ows?” version=“1.0.0” xmlns:xs=“http://www.w3.org/2001/XMLSchema” xmlns:ows=“http://www.opengis.net/ows/1.1” xmlns:wps=“http://www.opengis.net/wps/1.0.0” xmlns:xlink=“http://www.w3.org/1999/xlink”>
<wps:Process wps:processVersion=“1.0.0”>
ows:Identifier
gs:MBTiles
</ows:Identifier>
ows:Title
MBTiles
</ows:Title>
ows:Abstract
MBTiles Process
</ows:Abstract>
</wps:Process>
<wps:Status creationTime=“2024-02-09T12:13:32.609Z”>
<ows:ExceptionReport version=“1.1.0”>
<ows:Exception exceptionCode=“NoApplicableCode”>
ows:ExceptionText
Process failed during executionorg.geoserver.platform.ServiceException: Layer not found: catasto:test1Layer not found: catasto:test1
</ows:ExceptionText>
</ows:Exception>
</ows:ExceptionReport>
</wps:ProcessFailed>
</wps:Status>
</wps:ExecuteResponse>
It is possible that there is a bug in the class:
- geoserver/src/community/mbtiles/src/main/java/org/geoserver/mbtiles/gs/wps/MBTilesProcess.java
who considers searching only layers and not layer groups?
How can it be solved?
Thanks
Stefano
