We use the one that came with the geoserver 1.3.0 version. How can I
find out which one this is? Do I have to try a SLD and see the outcome?
Uli.
-----Original Message-----
Sent: Dienstag, 30. Mai 2006 18:30
To: Hans-Ulrich Otto
Subject: Re: [Geoserver-users] Bug in wms-SVG Renderer
Is this with the fast SVG renderer that does no styling? Or the slower
one that does do styling?
Hans-Ulrich Otto wrote:
We are using geoserver 1.3.0 with Oracle 10gR2 and tested the SVG
rendering of wms. E.g.
https://highway.teleatlas.com:8892/geoserver/wms?request=GetMap&width=50
0&height=500&format=image/svg&bbox=22.2253,60.4288,22.2608,60.44955&laye
rs=ta:MN_BU,ta:MN_LU,ta:MN_WL,ta:MN_WA,ta:MN_08,ta:MN_07,ta:MN_06,ta:MN_
05,ta:MN_04,ta:MN_03,ta:MN_02,ta:MN_01,ta:MN_00,ta:MN_PI,ta:MN_SM&styles
=MN_BU,MN_LU,MN_WL,MN_WA,MN_08,MN_07,MN_06,MN_05,MN_04,MN_03,MN_02,MN_01
,MN_00,MN_PI,MN_SM&BGCOLOR=0xF0F0D0
We get the following error message in the logs:
Error Performing SQL query: SELECT "ID", "FEATTYP", "FEATAREA",
"FEATPERIM", "NAME", "NAMELC", "BUACODE", "GEOM" FROM "MN_BU" WHERE
SDO_RELATE(MDSYS.SDO_GEOMETRY(2003,8307,NULL,MDSYS.SDO_ELEM_INFO_ARRAY(1
,1003,1),MDSYS.SDO_ORDINATE_ARRAY(8.86,44.3857,8.943,44.3857,8.943,44.44
5,8.86,44.445,8.86,44.3857)),"GEOM",'mask=anyinteract
querytype=WINDOW') = 'TRUE'
ORA-13226: interface not supported without a spatial index ...The reason is that that the parameters of the Oracle function
SDO_RELATE
are in wrong order:
Correct order: SDO_RELATE(GEOM_COL_IN_DB,BBOX_GEOM,OPTIONS)
Order in query above: SDO_RELATE(BBOX_GEOM,GEOM_COL_IN_DB,OPTIONS)We did not check if this is already fixed in the last recent version.
Hans-Ulrich Otto.
All the advantages of Linux Managed Hosting--Without the Cost and
Risk!
Fully trained technicians. The highest number of Red Hat
certifications in
the hosting industry. Fanatical Support. Click to learn more
http://sel.as-us.falkag.net/sel?cmd=lnk&kid7521&bid$8729&dat1642
Geoserver-users mailing list
Chris Holmes
The Open Planning Project
http://topp.openplans.org
