Hi.
I’m new on this. Great server.
Trying to create WMS with quite huge amount of MrSid’s. Just created mosaics (gdal tools), but now stuck with pyramids. There is sample http://geoserver.org/display/GEOSDOC/Load+NASA+Blue+Marble+Data . If you take look at the Step 3, there is text → Create a a new Run… task with the following parameters:
I can’t understand where to create new Run, where to type parameters ? Instruction says, not in GDAL, then where ?
Thanks.
