[Geoserver-users] building 1.4.x_merge_wcs
I’m anxious to try out the new WCS features so I tried building 1.4.x_merge_wcs from svn://svn.codehaus.org/geoserver/branches/1.4.x_merge_wcs
I first used maven2.0.4 to build the current GeoTools trunk – snapshot2.3/2.4. Then I tried ‘mvn install’ on 1.4.x_merge_wcs but I’m getting the following build failure:
[INFO] Compilation failure
D:\work-gt2.3\1.4.x_merge_wcs\wcs\src\main\java\org\vfny\geoserver\wcs\responses
\coverage\AscCoverageResponseDelegate.java:[12,32] package org.geotools.gce.arcg
rid does not exist
I can see that org.geotools.gce.arcgrid exists in the svn spike/arcGrid but if I attempt ‘mvn install’ I get this error:
[ERROR] BUILD ERROR
[INFO] Failed to resolve artifact.
Missing:
  1. org.geotools:gt2-imageio-arcgrid:jar:2.4-SNAPSHOT
My .m2 repository has an empty \org\geotools\gt2-imageio-arcgrid\2.4-SNAPSHOT but I can’t find imageio-arcgrid in the geotools svn?
Thanks
Randy
You have to update both pom.xml in the geoserver source and un-comment the dependency on such package, which should be:
<dependency>
  <groupId>org.geotools</groupId>
  <artifactId>gt2-arcgrid</artifactId>
  <version>${gt.version}</version>
</dependency>
Moreover, I had a problem with a non-existent class in a different package... but maybe someone has solved this already.
P.S.
Welcome to the cutting edge :wink:
    Luca Morandini
www.lucamorandini.it
-------- Original Message --------
Subject: Re:[Geoserver-users] building 1.4.x_merge_wcs
Date: 09/28/2006 01:01 AM
rid does not exist
[ERROR] BUILD ERROR
Missing:
1) org.geotools:gt2-imageio-arcgrid:jar:2.4-SNAPSHOT
Yesterday I tried the same as you, and succeeded, so there's still hope :slight_smile: I have geoserver-merge-wcs from svn running fine locally now. The solution is to build the spike/imageio directory, which will give you gt2-imageio-arcgrid.
Vincent.
Thanks
Randy
opinions on IT & business topics through brief surveys -- and earn cash
Geoserver-users mailing list
