[Geoserver-users] Building and Debugging GeoServer with extensions
I pulled the latest source from GeoServer master because I was going to look into fixing some of the bugs dealing with the GDAL Rest issues but do not know how to run GeoServer in debug with the extension enabled. I followed the steps for getting extensions and building using the following command mvn -Dskiptests -P allExtensions install and can run but do not see the GDAL raster types available when I run… Just the default types appear available. How do I get GDAL types available when debugging?
Hi Ben,
did you also properly install the native libraries part?
GDAL extension work on top of imageio-ext which also has modules working “as a bridge” between GeoTools/GeoServer Java code and GDAL C/C++ library (.DLL on windows, .SO on linux).
More info are available here:
http://docs.geoserver.org/stable/en/user/data/raster/gdal.html
Please, let us know.
Best Regards,
Daniele
On Fri, Feb 6, 2015 at 12:45 AM, Ben Johnson <weagle08@anonymised.com> wrote:
Dive into the World of Parallel Programming. The Go Parallel Website,
sponsored by Intel and developed in partnership with Slashdot Media, is your
hub for all things parallel software development, from weekly thought
leadership blogs to news, videos, case studies, tutorials and more. Take a
look and join the conversation now. http://goparallel.sourceforge.net/
Geoserver-users mailing list
Ing. Daniele Romagnoli
Senior Software Engineer
Via Poggio alle Viti 1187
Ben,
the trick when debugging GeoServer in Eclipse is to ensure that extensions of interest are on the classpath of the main application. The supported way of doing this is by enabling the Maven profiles of these extensions to add them as dependencies when generating the Eclipse project files for gs-web-app. In your case I think you need the -Pgdal flag.
Always generate Eclipse project files from the top level src directory to ensure correct inter-module workspace dependencies are generated. In your case the command will be something like:
mvn -PallExtensions -Pgdal eclipse:clean eclipse:eclipse
This will create Eclipse projects for all modules. (You can see the names of other profiles in src/web/app/pom.xml.) Add
You should then be able to refresh your Eclipse projects and launch GeoServer using one of the standard methods; for example using the embedded Jetty-based launcher by running this gs-web-app class as a Java Application:
src/test/java/org/geoserver/web/Start.java
Also try building with -Prelease to have the release demo data present in GeoServer at run time in Eclipse. This should have the same effect as these instructions:
http://docs.geoserver.org/latest/en/developer/maven-guide/index.html#building-the-web-module
Kind regards,
Ben.
the GDAL raster types available when I run... Just the default types appear
Ben Caradoc-Davies <ben@anonymised.com>
Software Engineer
Transient Software <http://transient.nz>
New Zealand
I also had some issues with GDAL native lib loading.
At the end I just dropped gdal libs to Windows/System32. It is not clean
solution but it worked for me. I never know from where java is gonna read
libs. Some times is root from where you start, sometimes from jdk location,
then LD_LIB_PATH, or PATH...
I have following gdal libs:
gdalconstjni.dll
gdaljni.dll
gdal19.dll
osrjni.dll
ogrjni.dll
I think just first three are mandatory.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Building-and-Debugging-GeoServer-with-extensions-tp5185868p5185985.html
Your suggestion worked Ben! Thanks!! Now to figure out the rest services in GeoServer… I’m not a Java dev… mostly C++ and C#.
On Fri, Feb 6, 2015 at 8:11 AM, uros <uros.mesaric-kunst@anonymised.com> wrote:
then LD_LIB_PATH, or PATH…
gdalconstjni.dll
gdaljni.dll
gdal19.dll
osrjni.dll
ogrjni.dll
