[Geoserver-users] [bulk]: Re: Geoserver fails to start - SOLVED!
Hello all,
Stefan made a guess:
Try using tomcat6 if the problem is still there.
He is right. I tried to install geoserver on CentOs 5.8 & tomcat5.
After I create a new server (CentOs 6) and installed tomcat6 & geoserver there, there is no problem. Geoserver runs smoothly.
Thank's all!
--pk
Pena Kupen [kupen@anonymised.com] kirjoitti:
Finally I found some time to this.
I'm still without success :frowning:
I'm unable to install newer tomcat (now 5) bacause of my hosting service.
After clean installation of 2.3, I check thru all logs.
There are two messages, which caught my eye.
>INFO: Deploying web application archive geoserver.war
>Mar 22, 2013 11:28:29 AM org.apache.catalina.loader.WebappClassLoader validateJarFile
>INFO: validateJarFile(/usr/share/tomcat5/webapps/geoserver/WEB-INF/lib/servlet-api-2.5.jar) - jar not loaded. >See Servlet Spec 2.3, section 9.7.2. Offending class: javax/servlet/Servlet.class
Seems to be only information
And then message, where starting up fails:
java.lang.RuntimeException: XPathFactory#newInstance() failed to create an XPathFactory for the default object model: http://java.sun.com/jaxp/xpath/dom with the XPathFactoryConfigurationException: javax.xml.xpath.XPathFactoryConfigurationException: No XPathFctory implementation found for the object model: http://java.sun.com/jaxp/xpath/dom
Anybody?
--pk
Wippies-vallankumous on täällä! Varmista paikkasi vallankumouksen eturintamassa ja liity Wippiesiin heti!
http://www.wippies.com/
Everyone hates slow websites. So do we.
Make your web apps faster with AppDynamics
Download AppDynamics Lite for free today:
http://p.sf.net/sfu/appdyn_d2d_mar
Geoserver-users mailing list
