If all Shape files have the same attributes and table structure, you could append the Shapes into one file before uploading to GeoServer using ogr2ogr:
ogr2ogr -update -append
Date: Thu, 17 Dec 2015 09:29:22 +0000
Subject: Re: [Geoserver-users] bulk shapefile import
but I’m not seeing an easy way to dump everything into a map layer.
All in a single layer? Does that mean they all have the same set of attributes?
Anyways, no, we don’t have a way to support that.
One way could be to import them into postgis and set up a view that selects all from those tables.
Does it really have to be a single layer? Could you not use a layer group?
From: Andrea Aime [mailto:andrea.aime@anonymised.com]
Sent: 17 December 2015 07:21
To: Alex O’Ree
Cc: GeoServer Mailing List List
On Thu, Dec 17, 2015 at 1:22 AM, Alex O’Ree <spyhunter99@anonymised.com…> wrote:
I’m attempting to import a large collection of shape files and want
them all added to a specific map layer. I found the “import a
directory of shape files” feature in the create a new data store admin
page, but I’m not seeing an easy way to dump everything into a map
layer.
also, do we have support for esri geo databases?
No supported way, but you could try using the geotools OGR data store
(there is no plugin packaging for it, you’ll have to build from sources):
https://github.com/geotools/geotools/tree/master/modules/plugin/ogr
Geosolutions’ Winter Holidays from 24/12 to 6/1
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
_______________________________________________ Geoserver-users mailing list Geoserver-users@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/geoserver-users
