[Geoserver-users] Bundled GeoWebCache - How to remove builtin grid sets?
In my newly installed GeoServer, the bundled GeoWebCache comes with a lot of built-in grid sets, most of which are useless for my usecases.
Version information : GeoServer 2.26.1 - bundled GeoWebCache
I would like to only keep a subset of them and some custom ones. The checkboxes of the built-in grid sets that would allow me to remove them are disabled. If I remember well this was nt the case in older versions of GeoWebCache. How can I remove built-in grid sets ?
The build-in gridsets are hard-coded and cannot be removed, sorry!
Thank you very much for your quick answer.
Not even possible by editing an XML config file?
Nope, you’d have to change some classes in the GeoWebCache sources:
Those gridsets are “built-in” because they come from an OGC specification, they are an international standard, when a client sees those well known names, it could avoid inspecting the full definition:
https://docs.ogc.org/is/17-083r2/17-083r2.html
Actually… version 2 of that standard is out and I believe some new built-in gridsets could be added as a result
Thank you very much one again !
