having a typical setup like
PostGIS => GS => GWC => Browser
Can I have preseeded tiles at GeoWebCache that are invalidated, that is get expired, on the fly based on caching headers?
That is, is the following possible?:
Browser re-requests a certain tile including If-Modified-Since header
GWC has a preseeded tile but needs to know if the tile is still valid. So GWC passes the request (still with If-Modified-Since) on to GS
GS looks up PostGIS to decide if tile is still valid or not. That is, if the data for the requested area has changed. Depending on that finding…
GS answers “304 Not Modified” or gives GWC the freshly generated tile
GWC updates its cache and passes answer along (either “304 Not Modified” or new tile)
I’ve read about Caching with Last-Modified or E-Tag headers at http://geowebcache.org/docs/current/services/responseheaders.html#last-modified-and-if-modified-since
However, this only handles the communication between browser and GWC. How about the “backend communication” between GS and GWC?
Best,
Jens
