I have a typical setup like:
PostGIS => GS => GWC => Browser.
Can I have preseeded tiles at GeoWebCache that are invalidated (i.e. get expired) on the fly based on caching headers?
That is, is the following possible?:
Browser re-requests a certain tile including If-Modified-Since header
GWC has a preseeded tile but needs to know if the tile is still valid. So GWC passes the request (still with If-Modified-Since) on to GS
GS looks up PostGIS to decide if tile is still valid or not. That is, if the data for the requested area has changed. Depending on that finding…
GS answers “304 Not Modified” or gives GWC the freshly generated tile
GWC updates its cache and passes answer along (either “304 Not Modified” or new tile)
I’ve read about Caching with Last-Modified or E-Tag headers at http://geowebcache.org/docs/current/services/responseheaders.html#last-modified-and-if-modified-since
However, this only handles the communication between browser and GWC. How about the “backend communication” between GS and GWC?
Best,
Jens
Hi Jens,
You could wire PostGIS with a trigger that invalidates portions of the GWC cache as changes take place, i.e. with pgsql-http.
https://github.com/pramsey/pgsql-http
Because, who doesn’t want a browser in their database? J
Best,
Steve
Stephen V. Mather
GIS Manager
(216) 635-3243 (Work)
clevelandmetroparks.com
From: Nachtigall, Jens (init) Jens.Nachtigall@anonymised.com
Sent: Thursday, August 21, 2014 9:25 AM
Subject: [Geoserver-users] Cache Invalidation (expiration) between GWC and GS
Best,
Jens
jive
August 21, 2014, 8:54pm
3
Part of the integration of GWC clears areas of the cache based on WFS-T transactions. You can produce a similar effect in a standalone GWC by giving it a georss feed.
Anyone up for turning your PostGIS changes into a GeoRSS feed
Jody Garnett
On Thu, Aug 21, 2014 at 6:25 AM, Nachtigall, Jens (init) <Jens.Nachtigall@anonymised.com > wrote:
Best,
Jens
Slashdot TV.
Video for Nerds. Stuff that matters.
http://tv.slashdot.org/
Geoserver-users mailing list
