On Mon, May 16, 2016 at 3:04 AM, James Sewell <james.sewell@anonymised.com> wrote:
Hey,
I work with Peter and have been looking at this too.
We are using drawing the map with Google, and pointing it to GeoServer to get this content.
What confuses me is that if we use WMS it all lines up perfectly, if we use GWC it isn’t even close. You can see from the images attached the difference I’m talking about - it’s definitely not a small mismatch!
The contents of this email are confidential and may be subject to legal or professional privilege and copyright. No representation is made that this email is free of viruses or other defects. If you have received this communication in error, you may not copy or distribute any part of it or otherwise disclose its contents to anyone. Please advise the sender of your incorrect receipt of this correspondence.
James Sewell,
PostgreSQL Team Lead / Solutions Architect
Level 2, 50 Queen St, Melbourne VIC 3000
P (+61) 3 8370 8000 W www.lisasoft.com F (+61) 3 8370 8099
On Sun, May 15, 2016 at 1:26 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
Mobile security can be enabling, not merely restricting. Employees who
bring their own devices (BYOD) to work are irked by the imposition of MDM
restrictions. Mobile Device Manager Plus allows you to control only the
apps on BYO-devices by containerizing them, leaving personal data untouched!
https://ad.doubleclick.net/ddm/clk/304595813;131938128;j
Geoserver-users mailing list
On Thu, May 12, 2016 at 4:56 AM, Peter Wang <peter.wang@anonymised.com> wrote:
However if I either add tiled=true or access via /gwc/service/wms then I see tiles created, but when they are rendered they are not aligned perfectly with the direct WMS or Google layers.
How much is the misalignment? GWC tolerates requests up to 10% off the tile grid structure, and will
respond with the cached tiles, which might be up to 10% off the exact coordinates you requested because of said tolerance.
If this is the cause try using the OpenLayers preview for the tile layers, as far as I know it is setup to perfectly match
with the GWC gridsets.
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
Ing. Andrea Aime
@geowolf
Technical Lead
