[Geoserver-users] Caching layers on the fly and seeding combination
I have created a map in geoserver Im am using geoserver 2.5.1 with the
intergrated geowebcache.
The map seems to be working fine and the seeding also seems to be working
fine provided I don't use a bounding box for some strange reason. But also
want it to cache on the fly as well so I can seed the main sections of the
map that would be used and have on the fly caching in the areas that arn't
being used as much.
Am I mistaken in thinking that it saves those certain tiles like the seeding
does or does it do it virtually or save in a temp tile folder and then goes
away instantly tht person either closes the map program.
I have set everything that I could set but for some reason on the fly
caching does not seem to work.
Am i missing something in the settings? Or am misunder standing something
with regards to it as in the geoserver documention states that it can
combine both on the fly caching as well as seeding the layers.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Caching-layers-on-the-fly-and-seeding-combination-tp5161049.html
When making the WMS getMap call, you have to change the URL to include prot://server[:port]/geoserver/gwc/service/wms?parameterlist
The important part is the gwc/service/ addition. Without it, the base WMS endpoint is called which does not utilize the cache (seeded or otherwise). When you include the service/gwc, the integrated GeoWebcache endpoint is called and with either return the existing tile based on seeding or generated, or it cascades the call to the normal WMS endpoint, caches the resulting tile and returns it.
Chris Snider
Senior Software Engineer
Intelligent Software Solutions, Inc.
-----Original Message-----
Sent: Wednesday, September 10, 2014 4:02 AM
Subject: [Geoserver-users] Caching layers on the fly and seeding combination
I have created a map in geoserver Im am using geoserver 2.5.1 with the intergrated geowebcache.
The map seems to be working fine and the seeding also seems to be working fine provided I don't use a bounding box for some strange reason. But also want it to cache on the fly as well so I can seed the main sections of the map that would be used and have on the fly caching in the areas that arn't being used as much.
Am I mistaken in thinking that it saves those certain tiles like the seeding does or does it do it virtually or save in a temp tile folder and then goes away instantly tht person either closes the map program.
I have set everything that I could set but for some reason on the fly caching does not seem to work.
Am i missing something in the settings? Or am misunder standing something with regards to it as in the geoserver documention states that it can combine both on the fly caching as well as seeding the layers.
Meet PCI DSS 3.0 Compliance Requirements with EventLog Analyzer Achieve PCI DSS 3.0 Compliant Status with Out-of-the-box PCI DSS Reports Are you Audit-Ready for PCI DSS 3.0 Compliance? Download White paper Comply to PCI DSS 3.0 Requirement 10 and 11.5 with EventLog Analyzer http://pubads.g.doubleclick.net/gampad/clk?id=154622311&iu=/4140/ostg.clktrk
Geoserver-users mailing list
