I'm using the ImageMosaic plugin to create a raster time-series layer
following the web tutorial. The files are png images that come with a world
file (pgw) and a project file (prj). The layer is created fine, and I'm able
to query the layer with a time attribute. However, when the tile caching for
this layer is enabled, the caching is not working. In the Tile layers page,
the layer appears enabled with a green tick. I have also modified the
property file, setting:
Caching=true
I have selected the "Enable direct integration with GeoServer WMS" option.
When the query is done without the time attribute, the caching is working (I
can see the tiles on the server):
But when the &TIME=2013-12-30T00%3A00%3A00Z is used at the URL the caching
doesn't work (though the layer is correctly shown).
Any idea of what may be the problem?
Thanks!
View this message in context: http://osgeo-org.1560.x6.nabble.com/Caching-raster-time-series-data-tp5101771.html
