[Geoserver-users] calculate extent/envelope of coverage
Hi
I’m using GeoServer to rasterize vectordata. For this I made a small web application where I can choose e suitable location and make a wms-request. The output is stored in a coverage store and also shown as wms in a second window (sounds a bit strange but we have to produce raster data from cadastral vector data at 508dpi). My problem is the changing of the extent/envelope of the coverage. Without changing and reloading GeoServer I have the right data at the wrong place. At the moment I put all the stuff in a directory that is visible from the intranet and I create also an info.xml with the right extent. In the data/coverage/MyCoverage/ directory I made a symbolic link to the info.xml. After all this I reload GeoServer with php (as described in the wiki). It all works fine except that I cannot saveToXml anymore (since there is no physical info.xml anymore). Is there a way to have GeoServer calculating the extent with php or perl or something similar? Any ideas?
regards
Stefan
Mit freundlichem Gruss
Stefan Ziegler
Leiter Aufsicht
Kanton Solothurn
Bau- und Justizdepartement
Amt für Geoinformation
Rötistrasse 4
4501 Solothurn
Telefon 032 627 75 96
Telefax 032 627 75 98
stefan.ziegler@anonymised.com
http://www.so.ch
Hmmm... tough issue. I know with feature types there is the ability to set the boundign to "dynamic". I am actually not sure what this does? (Andrea), but i would assume it means that it should be calculated on the fly.
I dont see the associated flag with coverages however. Perhaps it would make sense to add it there was well?
-Justin
Ziegler Stefan wrote:
Hi
I'm using GeoServer to rasterize vectordata. For this I made a small web application where I can choose e suitable location and make a wms-request. The output is stored in a coverage store and also shown as wms in a second window (sounds a bit strange but we have to produce raster data from cadastral vector data at 508dpi). My problem is the changing of the extent/envelope of the coverage. Without changing and reloading GeoServer I have the right data at the wrong place. At the moment I put all the stuff in a directory that is visible from the intranet and I create also an info.xml with the right extent. In the data/coverage/MyCoverage/ directory I made a symbolic link to the info.xml. After all this I reload GeoServer with php (as described in the wiki). It all works fine except that I cannot saveToXml anymore (since there is no physical info.xml anymore). Is there a way to have GeoServer calculating the extent with php or perl or something similar? Any ideas?
regards
Stefan
Stefan Ziegler
Leiter Aufsicht
Kanton Solothurn
Rötistrasse 4
4501 Solothurn
http://www.so.ch
!DSPAM:4007,48217b0261775409313003!
This SF.net email is sponsored by the 2008 JavaOne(SM) Conference Don't miss this year's exciting event. There's still time to save $100. Use priority code J8TL2D2. http://ad.doubleclick.net/clk;198757673;13503038;p?http://java.sun.com/javaone
Geoserver-users mailing list
Justin Deoliveira
The Open Planning Project
jdeolive@anonymised.com
Actually I believe nowadays it does nothing at all, but I'm not
completely sure.
Hmm... that would require some non trivial changes to how coverages
are configured. Doable for sure, but not a 5 minutes change, I would
need to assess how much code just assumes the envelope is there.
Simone, what do you think?
