[Geoserver-users] Can ArcGIS WMS GetMap requests use the GeoWebCache?
Hi GeoServer Users,
Any GeoWebCache gurus that know if WMS requests via ESRI ArcMap can use the GeoWebCache?
I have the tiled=true parameter set, but no new tiles are written to GeoServer’s integrated tile cache when viewing the layer via ArcMap.
I see in the online documentation that the OpenLayers layer preview is not compatible with the layer gridset, as it typically doesn’t line up with the cache gridsets due to the tileorigin being based on the layer bounding box. I wondered if ArcGIS might be doing the same thing.
Thanks in advance!
Ursula
You could use the url:
/geoserver/gwc/service/wms?
That will make use of the integrated GeoWebcache when serving a WMS request.
Roar Brænden
4. mai 2022 kl. 07:28 skrev Michael, Ursula (DEM) <Ursula.Michael@anonymised.com3...>:
UNOFFICIAL
Hi GeoServer Users,
Thanks in advance!
Ursula
Geoserver-users mailing list
Please make sure you read the following two resources before posting to this list:
- Earning your support instead of buying it, but Ian Turton: Earning Your Support Instead of Buying it
- The GeoServer user list posting guidelines: User group posting guidelines
If you want to request a feature or an improvement, also see this: Successfully requesting and integrating new features and improvements in GeoServer · geoserver/geoserver Wiki · GitHub
Geoserver-users@lists.sourceforge.net <mailto:Geoserver-users@anonymised.comeforge.net>
Many thanks Roar, got that in and it’s now trying to use the cache.
Unfortunately, it’s still not working as it’s throwing a grid alignment mismatch exception. From the logs it looks like ArcMap uses its own tile dimensions, and because the CRS, width, and height properties in the connection configuration seem to all be reserved parameters, I don’t think ArcMap can be forced to use the geoserver default gridsets.
It might be that I need to create some new gridsets to match esri and work out what the tile origin should be. Bit more investigating required I think.
Ursula
Sent: Wednesday, 4 May 2022 3:57 PM
To: Michael, Ursula (DEM) Ursula.Michael@anonymised.com
Subject: Re: [Geoserver-users] Can ArcGIS WMS GetMap requests use the GeoWebCache?
Roar Brænden
  1. mai 2022 kl. 07:28 skrev Michael, Ursula (DEM) <Ursula.Michael@anonymised.com>:
UNOFFICIAL
Hi GeoServer Users,
Thanks in advance!
Ursula
If you want to request a feature or an improvement, also see this: https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer
