On Thu, Oct 15, 2015 at 4:07 PM, David Haynes II <dahaynes@anonymised.com.> wrote:
Hello Andrea,
Thanks for the response. I came up with a work around that works pretty smoothly. Perhaps in the future it could be integrated it into an extension of the PostGIS JDBC connection. Since the PostGIS doesn’t set a limit on the number of bands within a raster dataset we have a large collection of rasters, well over 500 in our system. The example I am currently are 16 cereal crops around the world. What I ended up doing was ingesting the multiband raster into a single raster_table, gli.cereals with views o_2_cereals… o_16_cereals. Then I create a view for each CREATE VIEW gli.o_16_barley AS SELECT r.rid, st_band(r.rast, 1) AS rast FROM gli.o_16_cereals r; This is done for all of the datasets. The view are essentially queries on the cereals table so you aren’t duplicating your data, but using the function st_band allows you to extract a single band. Then the metadata table is created barley_mosaic and each view information is placed within the table. something like: ‘insert into gli.barley_mosaic(name, tiletable) values (‘gli.barley_mosaic’, ‘gli.o_16_barley’);’ make the xml and you are set to go.
I plan to implement this for a temporal stack of meris 300m satellite data.
On Mon, Oct 12, 2015 at 10:18 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
David Haynes, Ph.D.
Research Associate Terra Populus
Minnesota Population Center
612-626-3933
www.terrapop.org
On Mon, Oct 12, 2015 at 4:27 PM, David Haynes II <dahaynes@anonymised.com> wrote:
Seems that CQL expressions are not supported for this yet? Is there another way I can go about it. Visualization works fine if I specify a new SLD with the SourceChannelName set to band value (0-10)
Hi, no, band combining expressions are not yet supported in any form.
Using cql directly in SLD is rather elegant, I admit, it would require quite a bit of work and API breakage in GeoTools though.
A rendering transformation based on the Jiffle language would be less invasive and higher performing,
and we have the beginning of that solution written in this pull request https://github.com/geotools/geotools/pull/534
but yeah, also this would require resourcing to make it happen
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Ing. Andrea Aime
@geowolf
Technical Lead
