I have succeeded to generate tiles of my country in different zoom using the graet mapnick.
My question is: is geoserver able to serve the tiles generated by mapnick to have a slippy map of my country
If yes, can you give any link to help me to do this task, i will be very grateful
Thanks.
Le bonheur est comme l’écho : il vous répond : mais il ne vient pas.
I don't know if it is possible, but with GeoServer you have GeoWebCache.
The tiles are generated by GeoWebCache and served by GeoServer.
The tiles folders structure between GeoWebCache and Mapnik is maybe the
same.
Robin
ahmed2007 wrote:
the
graet mapnick.
to
grateful
Thanks.
Le bonheur est comme l'écho : il vous répond : mais il ne vient pas.
The NEW KODAK i700 Series Scanners deliver under ANY circumstances! Your
production scanning environment may not be a perfect world - but thanks to
Kodak, there's a perfect scanner to get the job done! With the NEW KODAK
i700
Series Scanner you'll get full speed at 300 dpi even with all image
processing features enabled. http://p.sf.net/sfu/kodak-com
Geoserver-users mailing list
View this message in context: http://www.nabble.com/Can-geoserver-use-tiles-generated-by-mapnick-tp23499672p23499901.html
Opposite, generated by GeoServer and served by GeoWebCache
You can stick GeoWebCache in front of Mapnik, but it really depends what you are trying to do. In general, GeoServer does not support WMS cascading.
-Arne
Spirifer wrote:
same.
Robin
ahmed2007 wrote:
the
graet mapnick.
to
grateful
Thanks.
i700
Series Scanner you'll get full speed at 300 dpi even with all image processing features enabled. http://p.sf.net/sfu/kodak-com
Arne Kepp
OpenGeo - http://opengeo.org
Expert service straight from the developers
