[Geoserver-users] Can Geowebcache return 404 when request zoom level > max zoom level?
Is it possible to have geowebcache return a http 404 when a request goes beyond the maximum zoom level defined
in the gridset in geowebcache.xml? The default configuration causes geowebcache to always return a empty transparent png.
Thanks in advance!
Best regards,
Sjoerd Brandsma
CycloMedia
Hi All,
Unfortunately I still haven’t found a solution for this.
Perhaps the only way is to do a software modification and build a ‘custom made’ geowebcache?
Thanks for any help.
Best regards,
Sjoerd Brandsma
On Thu, Dec 13, 2012 at 12:35 PM, Sjoerd Brandsma <sbrandsma@anonymised.com> wrote:
Thanks in advance!
Best regards,
Sjoerd Brandsma
CycloMedia
On Mon, Jan 21, 2013 at 10:54 AM, Sjoerd Brandsma <sbrandsma@anonymised.com> wrote:
Hi All,
Yep. Generally speaking, none of the released OGC protocols returns a HTTP code other than
200, only the new generation of protocols based on OWS 2.0 (to date, only WCS 2.0) will
start using propert HTTP codes.
So, to get what you want you’ll have to make a modification to GeoWebCache, if you want to
get it integrated in GeoWebCache it’s better if it’s also made configurable, as clients might
not be ready to handle it
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
