[Geoserver-users] can I configure the integrated GWC to support regular WMS clients?
Looking at http://geowebcache.org/docs/current/services/wms.html indicates it is possible with the external GWC but that would involve setting up a second server.
If I can manage with the integrated GWC life is much easier, but I don’t see a geowebcache-resources.xml file anywhere.
Ian
Ian Turton
Hum… from what I can see in that page:
GeoWebCache can recombine and resample tiles to answer arbitrary WMS requests. To enable this feature, open geowebcache-wmsservice-context.xml, find <propertyname="fullWMS"><value>FALSE</value></property> and change to <propertyname="fullWMS"><value>TRUE</value></property>. All layers that are to support this feature must currently be configured to support a PNG format.
That file is a Spring application context one, it’s no configuration file.
If you unpack the gwc-.jar file you’ll find a geowebcache-wmsservice-context.xml
file inside, that has the property above, currently set to false.
You can change it to true, re-pack, and see how that goes (btw, quality will be bad for
vector data, but should be ok for raster ones).
Still, pity that this behavior is not runtime configurable
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
