I was running gdal_retile on a 5TB data set. It was configured to create 10 levels of pyramids. The server crashed for a reason through during the weekend and it seems levels 0 and 1 were the only ones completed.
Whould it be ok if I start gdal_retile again? Will it re-do levels 0 and 1?
All the best,
A
Although the gdal_retile has been used to create pyramids to be served by geoserver, the gdal_retile command is a GDAL tool so I would probably ask that question to the GDAL list to be more sure1.
However, in my opinion, there is no way to skip the process to level 2 so I think you have to restart from zero and redo the job
Hope this helps.
Daniele
Ing. Daniele Romagnoli
Senior Software Engineer
Via Poggio alle Viti 1187
On Mon, Nov 11, 2013 at 2:29 PM, antchrysochoou <antchrysochoou@anonymised.com> wrote:
All the best,
A
November Webinars for C, C++, Fortran Developers
Accelerate application performance with scalable programming models. Explore
techniques for threading, error checking, porting, and tuning. Get the most
from the latest Intel processors and coprocessors. See abstracts and register
http://pubads.g.doubleclick.net/gampad/clk?id=60136231&iu=/4140/ostg.clktrk
Geoserver-users mailing list
There is a parameter pyramidOnly. (avoids retiling)
Christian
On Mon, Nov 11, 2013 at 4:10 PM, Daniele Romagnoli <daniele.romagnoli@anonymised.com> wrote:
Hope this helps.
Daniele
DI Christian Mueller MSc (GIS), MSc (IT-Security)
OSS Open Source Solutions GmbH
All the best,
A
