Hello,
I have a .png file with an associated .pgw which renders fine when I
specify EPSG:4326 as the value of the srs parameter in my WMS URL, but all
I get is a blank image when I specify a different value (such as a UTM
projection). Can anyone tell me whether reprojection of raster data should
work?
Any help on this would be GREATLY appreciated!!
Thank you in advance,
Deb
Debbie_Sikora@anonymised.com ha scritto:
Hello,
work?
Yeah, just add a .prj file with the proper wkt information and you should be ok. That is, xxx.png, xxx.pgw and xxx.prj. Use the same wkt that geoserver configuration panel shows you, but on a single line.
Alessio, since that world image does not have a native CRS, Geoserver
should have forced the declared one into it before sending it to
the renderer. Or not?
Oh, make sure your request with projected crs has a bbox in projected coordinates too.
