[Geoserver-users] Can we get SLD of a layer?
hi,
I use php script, and I want to get SLD of a layer? Can I do it with Geoserver 1.5.3 or later?
Nguyễn Đình Toán
Neu khong doc duoc tieng Viet, vui long vao menu View → chon Encoding → chon Unicode (UTF-8). Cam on.
Toan Nguyen ha scritto:
hi,
Nope, unfortunately at the moment we don't have such capability.
Yet, if you look into the WMS capabilies, you can get the style name.
If (and only if) the style name is equal to the file name, you'll
be able to grab the file by pointing your broswer to:
http://host:port/geoserver/styles/<styleName>.sld
For example:
http://geo.openplans.org:8080/geoserver/styles/tiger_roads.sld
thanks you
Nguyễn Đình Toán
What about the RESTConfig module? That allows for fetching of SLD based
on the style name, no?
RESTConfig is available on trunk, and as a plugin on 1.6.x too. Or is
it not in the downloaded 1.6.x packages?
--saul
> hi,
For example:
This SF.net email is sponsored by the 2008 JavaOne(SM) Conference
Don't miss this year's exciting event. There's still time to save $100.
Use priority code J8TL2D2.
http://ad.doubleclick.net/clk;198757673;13503038;p?http://java.sun.com/javaone
Geoserver-users mailing list
I did not suggest its usage because it's just a prototype, not sure how
working it is... and I believe on 1.6.x it just compiles but does not
really work.
David, what's the status of RESTConfig?
really work.
That's basically correct; however, the style code does seem to work (that is,
geoserver/rest/styles/<name>.xml does return the SLD). No promises
(RESTConfig is not at the top of my priority list these days), but I'll try
and be prompt in fixing any bugs reported.
-D
!DSPAM:4040,4808b8cc182481030819293!
