[Geoserver-users] Cannot add Geostationary satellite as custom projection to the SRS list of GeoServer
I have to serve GeoTIFF rasters extracted by gdal from Geostationary satellite hdf5 files. The images are provided in Geostationary projection (aka. "full-disc”, aka. “space-view”).
This projection, supported by GeoTIFF (http://www.remotesensing.org/geotiff/proj_list/geos.html) appears to be also available as custom to GeoServer.
I followed http://spatialreference.org/ref/sr-org/81/geoserver/ which says:
# put this custom projection in the ‘user_projections’ file inside the GEOSERVER_DATA_DIR
# You can further work with your projections via the web admin tool.
81=PROJCS[“unnamed”,GEOGCS[“unnamed ellipse”, DATUM[“unknown”, SPHEROID[“unnamed”,6378137,298.257223563]], PRIMEM[“Greenwich”,0], UNIT[“degree”,0.0174532925199433]], PROJECTION[“Geostationary_Satellite”], PARAMETER[“central_meridian”,0], PARAMETER[“satellite_height”,-0], PARAMETER[“false_easting”,0], PARAMETER[“false_northing”,0]]
Nevertheless after reboot, GeoServer doesn’t displays this projection in the SRS list (and there is no corresponding trace in logs) .
Of course I changed the values for “central_meridian” and “satellite_height” according to my data, then added the projection a single line string in the file /geoserver/data/user_projections/epsg.properties).
Moreover, EPSG provides 2 other valid orthographic projections (EPSG:9839,9840), which are not listed in the SRS list of the GeoServer.
Did someone already successfully added Geostationary projection (or other orthographic projection) to GeoServer to serve raster as WMS?
Many thanks,
Victor
