[Geoserver-users] Cannot create JDBC driver of class 'org.postgresql.Driver'
Greetings,
When I try to create a Vector Data Store I get the following error:
Error creating data store, check the parameters. Error message: Unable to obtain connection: Cannot create JDBC driver of class ‘org.postgresql.Driver’ for connect URL ‘jdbc:postgresql://https://xx.x.xxx.xxx:xxxx/mout?sslmode=ALLOW&binaryTransferEnable=bytea’
Any thoughts on how to get past this?
I’m using · GeoServer Version 2.19.0
Thank you,
Is that a JNDI connection string or something that GeoServer has constructed for you. I’ve never seen a PostgreSQL url with parameters like that before.
Next step is probably to turn up the logging level and see what happens in the log file
Ian
Ian Turton
A quick google search shows that the URL for the postgres connection is of the form:
· jdbc:postgresql://host:port/database
You probably want something like
Jdbc:postgresql://myserver:5432/mydatabase
see this link for more info:
https://jdbc.postgresql.org/documentation/80/connect.html
Hope this helps
Graham
Sent: Thursday, 12 August 2021 12:31 AM
Subject: [Geoserver-users] Cannot create JDBC driver of class ‘org.postgresql.Driver’
Greetings,
Thank you,
