Hi folks,
I compiled GDAL with ECW support under Ubuntu 12.04 for use with
geoserver 2.3.4. I followed the instructions at
http://docs.geoserver.org/stable/en/user/data/raster/gdal.html
But the ECW store doesn't show up in the admin interface. I also set
LD_LIBRARY_PATH and GDAL_DATA in /etc/environment but nothing seems to
work.
Is there anybody that has a succesfull ECW implementation that wants
to share some hints? Technical information is attached inline.
Kind regards,
Milo
GDAL
./configure --with-ecw=/usr/local --with-java=/usr/local/java/jdk1.6.0_45/
Output is then:
GDAL is now configured for x86_64-unknown-linux-gnu
Installation directory: /usr/local
C compiler: gcc -g -O2 -DHAVE_SSE_AT_COMPILE_TIME
C++ compiler: g++ -g -O2 -DHAVE_SSE_AT_COMPILE_TIME
LIBTOOL support: yes
LIBZ support: internal
LIBLZMA support: no
GRASS support: no
CFITSIO support: no
PCRaster support: internal
LIBPNG support: internal
DDS support: no
GTA support: no
LIBTIFF support: internal (BigTIFF=yes)
LIBGEOTIFF support: internal
LIBJPEG support: internal
12 bit JPEG: yes
12 bit JPEG-in-TIFF: yes
LIBGIF support: internal
OGDI support: no
HDF4 support: no
HDF5 support: no
NetCDF support: no
Kakadu support: no
JasPer support: no
OpenJPEG support: no
ECW support: yes
MrSID support: no
MrSID/MG4 Lidar support: no
MSG support: no
GRIB support: yes
EPSILON support: no
WebP support: no
cURL support (wms/wcs/...):no
PostgreSQL support: no
MySQL support: no
Ingres support: no
Xerces-C support: no
NAS support: no
Expat support: no
libxml2 support: no
Google libkml support: no
ODBC support: no
PGeo support: no
FGDB support: no
MDB support: no
PCIDSK support: internal
OCI support: no
GEORASTER support: no
SDE support: no
Rasdaman support: no
DODS support: no
SQLite support: no
PCRE support: no
SpatiaLite support: no
DWGdirect support no
INFORMIX DataBlade support:no
GEOS support: no
Poppler support: no
Podofo support: no
OpenCL support: no
Armadillo support: no
FreeXL support: no
SWIG Bindings: no
Statically link PROJ.4: no
enable OGR building: yes
enable pthread support: yes
enable POSIX iconv support:yes
hide internal symbols: no
gdalinfo --formats | grep ECW
ECW (rw): ERDAS Compressed Wavelets (SDK 3.x)
JP2ECW (rw+v): ERDAS JPEG2000 (SDK 3.x)
gdal-config --version
1.10.0
2013-08-22 01:37:09,930 INFO [xml.XmlBeanDefinitionReader] - Loading
XML bean definitions from URL
[jar:file:/var/lib/tomcat6/webapps/geoserver/WEB-INF/lib/gdal-2.3.4.jar!/applicationContext.xml]
2013-08-22 01:37:21,672 DEBUG [gdal.dted] - DTEDFormatFactory is not availaible.
2013-08-22 01:37:21,672 DEBUG [gdal.jp2mrisd] - JP2MrSIDFormatFactory
is not availaible.
2013-08-22 01:37:21,672 DEBUG [gdal.envihdr] - EnviHdrFormatFactory is
not availaible.
2013-08-22 01:37:21,673 DEBUG [gdal.mrsid] - MrSIDFormatFactory is not
availaible.
2013-08-22 01:37:21,673 DEBUG [gdal.ecw] - ECWFormatFactory is not availaible.
2013-08-22 01:37:21,673 DEBUG [gdal.nitf] - NITFFormatFactory is not availaible.
2013-08-22 01:37:21,675 DEBUG [gdal.jp2k] - JP2KFormatFactory is not availaible.
2013-08-22 01:37:21,675 DEBUG [gdal.rpftoc] - RPFTOCFormatFactory is
not availaible.
2013-08-22 01:37:21,675 DEBUG [gdal.jp2ecw] - JP2ECWFormatFactory is
not availaible.
2013-08-22 01:37:21,675 DEBUG [gdal.erdasimg] - ErdasImgFormatFactory
is not availaible.
2013-08-22 01:37:21,675 DEBUG [gdal.ehdr] - EsriHdrFormatFactory is
not availaible.
